is there a difference with 3/4 ton rear and a 1 ton rear (14 bolts?)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jakeslim, Apr 30, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Whats the diffence if any? Are the internals the same? Are both ff? prefer to get the 3/4 ton because I can't relocate the perches myself and don't want to pay to have it done.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The only differences are the spring perch location and the shock mounts.
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks, just wanted to be sure.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Guts in the housing are the same, shafts are the same, the only difference is the 1 ton brakes are bigger and the perches and shock mounts. Also if you plan to keep it drum braked make sure you have the correct e brake set up on the 3/4 ton axle.
  5. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    is this the same as with a 1/2 ton vs 3/4 ton...the innerds are the same?
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    There are no FF14Bs in a 1/2 ton.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Some 3/4 tons came with the 11.5" brakes, and some came with the 13" brakes like the 1 tons used. So both brake options are available in the 3/4 ton package with the right perch mounting locations.
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    You're partially correct on this. The 3/4 ton 13" brakes use shoes that are about 2.5 inches wide, while the one ton 13" drums use shoes that are 3.5 " wide IIRC. I might be off on the numbers, but I know the one ton brakes have wider shoes/drums.
    So one ton axles have different spring pad widths, shock mount locations, and bigger (wider, not larger diameter) drum brakes.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You are correct. I forgot that the 13" is the same between the large 3/4 ton and 1 ton, but the shoe width is different.
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    One more difference, on the 1 ton axles, the e-brake cables run down the drivers side.
  11. yellow81k10
    yellow81k10 Registered Member
    Apr 1, 2003
    15
    Parma Idaho
    spring perches are easy and cheap to move. had mine moved for about 40 bucks. only other differences are brake drum width and shock mounts
  12. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    I think that actually has more to do with the year of the vehicle than the axle.
  13. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    The spring perches may be cheap to have moved, but moving the axle around town is not easy or desired. I had to rent a van to pick up my d60. If I can pick up a 3/4 ton and be done with it, all the better! If only i could weld....
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    ZING! ZING! We have a winner! /forums/images/graemlins/rotfl.gif All the statements you described are true.
    The 11" drums use a 2.5" wide shoe, FYI. /forums/images/graemlins/wink.gif
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    ZING! ZING! Another winner! /forums/images/graemlins/rotfl.gif
    Actually, the '77 to '84 axles have 'equal-length' cables which fasten to a mount by the forward part of the rear spring hangers.
    The '85 to '91 axles have the passenger side cable running over to the driver side to run '2 into 1' cable. /forums/images/graemlins/thumb.gif
