is there a differnece in disc and drum brakes d44 knuckles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4 Cowboy, Jan 7, 2003.
  1. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    is there a differnce in the way they look depending on what brakes you have
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    A friend of mine converted his drum brake front to disc, and he had to get a couple knuckles from me off a '74 D44 front with disc brakes. He said the backing plates wouldnt bolt up properly on the his old drum knuckles.
    I had a '67 D44 closed knuckle front with drum brakes, and that was completely different.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Heres a pic of the older Dana 44 with drum brakes.
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    That's the closed knuckle variety which can not be converted to disc. A 1970 axle will have drums in front with open knuckles and can be converted to disc.
  5. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    from what im told the knuckles with drum brakes have the bolt holes for the spindle indexed differently, causing the caliper to be rotated too much
