Is There A Easy Way To Gain An Extra Inch Of Lift????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Jan 2, 2004.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My 86K5 has 4"suspension lift and 2" body lift. I am in the middle of putting a 14bolt SF on it and changing the front diff. Is there a cheap and simple way of adding another inch of lift some how. Its time for rims and tires I want to run 38's.
    Thanks /forums/images/graemlins/k5.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Zero-rates sandwiched under the leaf springs or a 1" body lift. /forums/images/graemlins/thinking.gif
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Yep, like Wes said. Zero rates are the way to go.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    As the guys said, zero rates - and since you only have 6 posts, you might not know what they are or where to get them - www.offroaddesign.com is the place.............
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Also, IF you go with 38's I would suggest getting a D60 front along with your 14BFF if you wheel it much because you will probably have problems with a D44 or 10B. WIth one tone gear that will raise you one inch just from the bigger axle tubes and different spring perches. I would also add the zero rates too if you really wan't 38's.
  6. Monster
    Jun 14, 2002
    68
    They say there not blocks but they look like blocks.
    I already have blocks in the rear could i still use the zero rates.???????? What about a add a leaf??
    ROUGH COUNTRY makes a add a leaf kit would that be ok??
    I dont off road its just a pavement pounder.
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Sounds like you need to do a shackle flip you'll gain lift and loss the blocks. Do a search on shackle flips and read up.
  8. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    zero rates, or ditch the block and go with the 57" springer setup, shackle flip, homemade shackle reversal..etc.. all those will make the truck ride better.. /forums/images/graemlins/thumb.gif
