is there a logical reason for bigger or smaller lockrings on beadlocks?
Discussion in 'The Garage' started by spongeidys, Jan 25, 2006.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    whats the diffrence between the normal small lockrings compared to the big ones? is it just cosmetic? depends on make? or are there pros and cons to running a certian style? will letting water sit in the lip of the rim do any harm in terms of rust and will water that lays inbetween the ring and and rim have any effect while it touches the tire sitting inbetween the 2?
    small lock ring with water sitting in it
    big lock ring
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the beigger rings help keep rocks out too. someone here had the wide rings with a snap in center so no mud could get in then pop it out to change the tire. i'v seen small rings get bent on a sammy with 33's so i went with kerts on my 38's for mine.
