is there a point to pullin off the belt on a busted air compressor...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by amm888, Apr 11, 2003.
  1. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    ...or is it an air condensor? my ac doesn't work and i ain't plannin on fixin it (no time soon, at least). if i cut the belt around the compressor will i free up a little more power? will it effect anything else?
    i think there's been previous discussion about this, but i couldn't find jack on the search (so don't yell at me!)
    thanks
    alex
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Does the belt drive any other accessories?
  3. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    hmmm...good question. i don't really know. i don't think so, but how do you check for sure?
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Well, open up the hood, and see how the belt is routed throughout the throng of accessories. If that belt is only driving the air compressor, then all is good. If it drives something like the alternator, then no you can't remove it.
    I don't know about the earlier K5's, so you will just have to look under the hood or wait for someone who knows them to tell ya. It's not that hard. /forums/images/graemlins/thumb.gif
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Alex, I think it also drives the AIR pump (smog thing). A GM mechanic told me (IIRC) that if you remove that belt, that pump doesn't work and it affects how the truck runs.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The mechanic was full of it. I unhooked my AIR pump a few months ago and it hasn't affected the truck one bit.
  7. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Well, I have noticed one thing about unhooking air pumps. They tend to have a high state of lockup when they are not used. I'm not sure why, but that is my observation.
    Blake
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Yup, I've read that. I guess I'll cross that bridge if I'm still in this smog nazi state come registration time in a year.
  9. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It isn't going to make much of a difference since the compressor doesn't run unless you tell it to. The belt probably also drives the power steering pump. But the power steering pump probably has its own belt too. Mine does.
    One of the things you can do is get rid of the AIR pump. You don't need that. Just make sure you block off all the junk when you remove it.
  10. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    i just took a closer inspection of the whole belt deal, and it appears that the belt is only fully around the thing that is driving it. one 'leg' of the belt kinda side swipes another wheel, but that wheel seems to have it's own seperate belt that is driving it - sorry guys, i don't know the names for these things.
    BUT, what i'd also really like to know is - is there a point to cutting the belt? will i get any more production from anything else? or should i just leave it as is?
  11. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    Pam,
    i'm not sure if my truck has all the smog stuff - when i had it smogged the guys told me that my truck didn't have very high standards to pass cause it was a federal truck (i think that's what he said, something about the state it was produced in) and therefor didn't need to have all the smog stuff.
    i could be wrong.
  12. Skigirl
    Apr 2, 2001
    2,563
    Alex,
    If that's a federal truck, you lucked out I think. Landsmasher has a federal truck too, and it came stock 3/4 ton instead of 1/2. More heavy duty than 1/2 tons like mine.
    Dunno about smog standards tho. Yours runs well enough I'd bet it'd pass and they wouldn't notice whether you had the AIR thing on there or not. /forums/images/graemlins/thumb.gif
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Some people belive the belt drags and robs HP. I can't say one way or the other. If it's not driving anything else, it couldn't hurt to remove it.
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    just leave it...if you ever fix it, you might have to remove other belts to put that one back.
  15. dyeager535
    26,979
    You won't free up any noticeable power...it's a clutched setup, and only drives the pump when it's commanded.
    One thing you might do if it doesn't work (as in all the freon leaked out) is to unplug it. Don't think unplugging the unit will change anything, except there will be no chance that it's taking any power from the engine if the switch gets hit to AC.
    As an aside, can anyone comment on whether the later units ('81+) command the compressor on when its in the defrost position, like some other GM vehicles?
  16. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    Yep, the compressor should engage when the defrost is selected.
  17. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    My 84 does. It's there to keep vehicles with air conditioning in the northern climates from ending up with a noisey pump after not being used for months.
  18. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    A normal V-belt is 94-98% efficient as long as the pulleys are aligned perfectly and the right tension is used. A cogged v-belt is supposed to be 1-2% more efficient because it's more flexible. Those synchronous belts they use on superchargers are supposed to be 98-99% efficient.
    As a side note, a spur gear system is about 98% efficient. Hypoid gears (like you see in motorcycles) are a lot less efficient. Worm gears are terribly inefficient.
  19. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Yup.
  20. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    thanks all - i'll just be leaving it in then.
