is there a rebuild kit for power steering pumps?
Discussion in 'The Garage' started by **DONOTDELETE**, May 3, 2002.
    mine leakes from behind the pulley and the pulley has a slight wobble to it. but it doesn't sweel or grown and otherwise works great. so can i get it rebuilt - some kind of new seal and bearing or do i junk it and take my chances on a junk yard one?
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I had the same problem,but instead of buying a rebuid I just replaced the whole pump. I went to the local parts store and got a new pump and reseivor for $75 bucks.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've replaced the seals in one before. It's not too hard, if you have the tool to remove and install the pulley. Otherwise, fuggeddaboutit! /forums/images/icons/wink.gif The seals are pretty cheap.
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    You can go to your local dealer & get an AC Delco re-man pump for 70.00 to 80.00 bucks and be done with it....
    Jim
  4. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I got a reman pump w/ resivoir at Napa for $45. A $16 core charge. Deffinetly use an install/removal tool on the pully. I got 1 thru loan-a-tool at Autozone, $40 deposit.
    Later Ed
  5. napa seems like the ticket. for some reason i thought they where more than that. thanks all
  6. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ya, what he said...lol...you can get a seal for it for like 3-4 dollars, and you just gotta get or have the tool for the pully.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    When I did mine I had a harbor freight puller, it broke the first time out of the box.
    I just took the pump (once removed from the resivoir) to Napa where I bought the pump and they removed the pully.
    The new pump will come with a pully installation tool.
