Is there a slip yoke eleminator kit for a NP208?
Discussion in 'The Garage' started by Klink K5, Feb 23, 2004.
  1. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Just wondering if I can get the style of kit that is offered for the NP241 for my 208 in my 1986 blazer . I have not reasearched this so dont flame my thread. I would also if there is away to get rid of the slip yoke if there is a kit not avaliable .Thanks, KLink /forums/images/graemlins/waytogo.gif
  2. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    I dont think there is a kit, because there are dodge 208 cases that have a standard yoke. You just swap the parts into your 208 and be done with it.
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    There isn't a kit like the one for the 241. Also, the dodge conversion isn't 100% bolt together because the dodge rear case doesn't have mounting points for the strut.
  4. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    There is a kind of slip yoke eliminator for them, but all it really is, is a hole drilled/tapped into the output shaft and a bolt inserted there. It does nothing for the length but it does keep it from slipping out, worthless in my opinion.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    There is no good kit available, which is amazing due to the millions of 208 cases sitting in Chevys and Fords around the world.
    There is the Dodge/Chevy hybrid plan, but only a couple of guys here have ever done it and to be a direct replacement, you have to weld chevy threaded parts onto the back half of the Dodge case you would be using. I looked around here and Dodge fixed yoke 208 cases are like $350+ in scrapyards.
    Then there is the bolt on flange that goes with an unmodified 208. It will actually shorten your driveshaft a little bit. This solves the driving with no rear driveshaft and spline binding problems, but doesn't get rid of any slip-yoke slop. You can see an example here
    I heard Jess at high angle was working on one, but it has never materialized. Not knowing any better, I think it should be pretty similar to the kit for the 241.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Andy SYE's 208s, PM him.
  7. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    So the fixed yoke dodge 208 that i got when I traded an old th350 from a 2wd was a good deal then? /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I have a Dodge/Chevy hybrid 208. All I know is in fact it has some custom welding done to it, I've never taken it apart, much less got it on yet...........
  9. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I also have a chevy/dodge hybrid. You have to weld a piece inside the case and you have to weld the threaded pieces for the support rod.
