Is there a trick to getting the snap ring out of a 14 bolt hub?
Discussion in 'The Garage' started by afroman006, Feb 17, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I'm rebuilding my 14 bolt and am stuck on the outer hub bearing. I cant get the snap ring holding it in out. I've managed to squeez it closed with needle nose pliers but I cant get it out of its groove, if I try to pull it the pliers slip and I usually hurt my self /forums/images/graemlins/rolleyes.gif. So, is there a special tool or trick to get this dang ring out? Thx
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I used a pair of needle nose withthe 90* bend in them. Pain in the A$$, but I got it out /forums/images/graemlins/thumb.gif
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Ohhhh that damn snap ring is such a pain. Get a pair of needle nose pliers that have a fairly long handle. I got a big nail and put it in a pair of vice grips, and after squeezing the ring with the pliers I used the end of the nail to get under the snap ring and pull it up out of the hub. Work one side and go around while pulling up. You may bend the snap ring a little (I did) but just tweak it back to shape when you get it out. It's cake putting it back in when you get there. /forums/images/graemlins/thumb.gif
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    2 picks work good also.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I don't remember that part when i had mine apart, but is it something that actually requires "snap ring pliers?" /forums/images/graemlins/eek.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Don't forget to drive the race away from the snap ring slightly or it will be much harder to remove the snap ring.
  7. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    you could have the different hub nut system.... the one with a washer against the bearing, then a hub nut, then a retaining washer with little tabs on it, then a hub nut, then you bend one of the little tabs down into one of the grooves on the outer hub nut.
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    OK, yeah thats right, no snap rings in my setup. maybe that's why i don't remember it huh? /forums/images/graemlins/whistling.gif
  9. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Actually, the snap ring he is asking about is located between the inner and outer bearings and retains the outer race in the hub. It has nothing to do with the double axle nuts and lock tab washer that are removed to get the hub off the axle housing.
    I have found the best way to get them out is to squeeze the two ends together with grooved snap ring pliers or just use some long needle nose pliers to free it up as much as possible. If you are lucky this will remove it, but most likely it won’t. Now take a long drift or flat screwdriver and hammer and try to drive the snap ring around inside the groove, rotating it around in the hub. This will free it up and you can now get it out with the pliers.
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if you notice who i responded too..... i was talking to 4xcrazy about his axle, because he said he cant remember a snap ring on his axle when he was inside it.
  11. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    No worries! My point is that it has nothing to do with the “hub nut system”. The snap ring he was asking about is in the middle of the hub and cannot even be seen until the hub is removed from the axle, the axle seal is removed and the inner bearing is removed.
  12. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ahh ok i see where we are talkin about lol.... /forums/images/graemlins/ignore.gif
    had to re read the first post.
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's the part that makes it much easier to get that snap ring out of there! Also, be SURE that you seat the new race FIRMLY against the snap ring during reassembly. If you don't then the pressure against the bearings while driving will push the race into place and the bearings will then be very sloppy. If you don't catch it right away it can ruin the bearings, hub and spindle. /forums/images/graemlins/eek.gif
  14. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    It takes a two headed screwdriver /forums/images/graemlins/peace.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Damn I been waiting months for a good what tool post /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  15. afroman006
    Aug 21, 2002
    2,876
    Lol. I've tried sticking a little screwdriver in there to wedge the ring out but its really hard keeping enough pressure on the pliers and manipulating other tools at the same time. That damn little clip is strong! I've moved the race around a little bit but it very well might be wedged against the clip, I'll check tomorow. JJ, where can I get me one of them? Looks like a Craftsman to me. If you take it back will they give you two normal screwdrivers? Thx for the help.
  16. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i think the answer is just to keep fumbling it like the rest of us here! As you can see there are many ways to pluck that sucker out of there! I had my fun with and and think I had two screwdrivers and pliers to make it happen!
    too much fun though. Once you get it out your home free though /forums/images/graemlins/waytogo.gif
  17. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I use a razor blade, to move it up then just follow a flat blade along the out side, works like a charm everytime I also do this to the d44 /forums/images/graemlins/thumb.gif
