Is there a way to identify a 14bff gov lock?
Discussion in 'The Garage' started by socal chevy, Dec 14, 2004.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    Is there a way to identify a 14bff gov-lock WITHOUT looking inside the diff?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    isnt any sure fire way to do it without looking inside.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    jack your truck up in the rear, spin on of your tires as fast as you can, if the oppsite tire catches, you have a govlock, just grab it and give it a good hard spin, the other tire will jerk and spin the same way:waytogo: worked for me
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Then again, you could always check this out: Lookee Here It's a 12 bolt, but they probably look similar.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Actually the 14FF carrier looks nothing like a 12 bolt does.
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    ...unless the axle has a detroit or other locker.
    socal, didn't you make the post about ID'ing the gov lock? weren't the pictures of each enough to help you decide?
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, there was a post I remember. I was about to say the same thing.
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
  9. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Without pulling the cover you can look for the RPO code. Also, every 14 bolt Gov Lock axle I've seen has (or had) a black rectangular stick on the cover (off center towards the driver side). Typically, the sticker is long gone but it leaves a distinctive spot on the cover.
    Of course, without pulling the cover this is all still a guess since you never know if the carrier has been replaced or if the cover has been swapped.
  10. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I asked about the inside, no the outside...relax fool. :)
