is there an axle?
Discussion in 'The Garage' started by ijakers, Jan 17, 2004.
  1. ijakers
    ijakers Registered Member
    Apr 2, 2003
    34
    St. Martinville, Louisiana
    is there a 14b rear axle that is the same width as the front axle that will just bolt on and still retain my 6 lug wheels? oh by the way, i have an 86 k5 with the stock 10 bolt rear. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
    thanks Ike
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not a bolt on one, no. Scroll down to the 14 bolt upgrade thread in the 73-91 forum, your question has been answered over the last couple days already.
    There are several options for staying 6 lug. I personally suggest just going 8 like the rest of us.
  3. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    yes, you can use a 14 bolt semi float axle that is 6 lug, and found in later chevy's or if you find the 8 lug, you can always swap shafts and drums, or use the 14 bolt full float and get some 8 to 6 lug adapters; no as to it being the same width
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The adapters can cure that problem though....
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The Savana/Express 2500LD is a 6-lug 14SF as well... I bet its wider than the pickups.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And none of those axles will "bolt in" to our trucks, so it doesn't matter.
    Nothing 6 lug will bolt in. You can get a bolt in 8 lug semi floater and convert it to 6 lug or use the adapters. But nothing that came 6 lug from the factory is going to have the right spring pads for our trucks.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    why wont a 6 lug 14 SF bolt under a 42.5" spring pack truck ?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Because the 88-98 trucks that they come from use a different width.
  9. ijakers
    Apr 2, 2003
    34
    ok, stupid question time what is the difference between semi floater and full floater? /forums/images/graemlins/thumb.gif
  10. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Some of the suburbans in the 87 to 89 years used 6 lug 14sf's that will bolt right into our trucks.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If this is true, I've never seen or heard of one. Makes sense though.
    If that's true those would be the only 6 lug 14 bolts that will bolt in.
    (above poster)
    Everything is different between a full floating axle and a semi floater. The axle is of an entirely different design. With a semi floater, the tires are bolted to the axleshaft which supports the weight AND drives the tires.
    On a full floater, the tire is bolted to a hub which rides on a spindle which is bolted to the AXLE HOUSING itself which supports the weight, the axleshaft simply drives the tire.
  12. ijakers
    Apr 2, 2003
    34
    would the axles from these subs be the same width as the front axles on the blazers?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not exactly, but close enough.
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    Sounds like a hen's tooth... I've never seen/heard of 6-lug 14SF for an 81-91 Burb. Some people do swap the 6-lug shafts into the 3/4-ton (8-lug) housing.
    Actually GM didn't egt any smarter... the 92-00 Burbs never used a 6-lug 14SF either (although the one from a pickup does bolt in). Haven't had a close look at the 01-up models yet.
  15. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I think the ss454 2wd pick ups had the six lug/sf but never seen one just hearsay.. /forums/images/graemlins/usaflag.gif
  16. u2slow
    May 9, 2001
    2,217
    BC Canada
    Nice catch! /forums/images/graemlins/thumb.gif
    The 454SS is a 14SF, but is 5-lug.
  17. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Hey Broussard, LA. /forums/images/graemlins/thumb.gif Local boy. Check out the southeast forum sometime.
  18. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    As long as mankind has existed, we have asked this timeless question.
    Personally, although I have never met "axle", it seems more logical that HE does exists than that he does not. This is called FAITH.
  19. audacious
    audacious Registered Member
    Mar 10, 2003
    34
    tx, austin
    i have the 86 set up also and just to throw my 2 cents in i got a van width (same size as frount) 14ff 4.10 and a matching frount 10bolt from the junkyard for 300. great shape and with some modifications and a little money i can have a set of 8 lug axles in my truck ready to go. granted i lose the 6 lug but it is worth it and way cheaper than trying to regear and change the lug set on the axles. my say is just to keep the 10 bolts and upgrade to 8 lug if you are going to change the axles.the 10 bolt are pretty good for most intermidiate uses anyways.
