Is there an in tank pump?
Discussion in '1982-Present GM Diesel' started by Pookster, Apr 17, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    been looking at running the straight veggie oil conversions , with a seperate tank, none of the conversion units ever talk about " a pump". So i assume, that there is none, and that the only pumps are the injector pump, and the lift pump which somehow sucks the fuel from the tank.
    Does this seem right?
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Non of the factory GM 6.2/6.5s had in-tank pumps. Lift and IP did all the pumping.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So in theory, I could have a rubber hose dippin into a 55 gallon oil drum and just let it get sucked out? (obviously priming the line so that there is no air in it)?
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Assuming the veggie oil is good and warm and the connection to the tank was on the bottem (assuming the tank was in the bed). When the oil becomes cold you may have some problems pumping it.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Not to seem like a moron, but... After I shut down my truck, I seem to hear some noise from the rear for a few moments. The sound seems like a fuel pump! Almost like a mild hum. Funny thing is, I dont hear it during the pre-start phases!
  6. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    It kinda makes sense. In the 6.2/6.5 Diesels fuel is circulated from the tank to IP to Injectors back to the tank. If you were driving for a while you probably heated the oil up reducing it's thickness allowing for a more noticeable pump noise when warm.
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Kinda Lost. Previously it was stated that there is no "in tank pump".
    Ok, the fuel heats up from circulation, that makes sense.
    But if there is no pump in the tank, why am I hearing it? is there a supplimental pump somewhere along the system?
  8. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    No in tank pump. Depending on the year of your truck you may have an inline electric "Lift Pump" located on the frame rail under the drivers side door.
  9. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    That must be the noise im hearing. i'll crawl under and check it out tomorrow.
