is there another limited slip other thangov-loc from the factory?
Discussion in 'The Garage' started by big_truxx, Aug 28, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    i am curious since never have had the 89 crew dual's rear diff off. would the only option gm would have for something that spun both sets of wheels be the gov-bom? i know it spins all 4 rear wheels when ya romp on it.... or was there another option that the truck may have?
  2. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    also looked at the rpo codes on glovebox and no G80.... but i know it has spun all 4 rear wheels together... and not a feature of an open diff... :confused:
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Are you sure the PO did not install something. I could have a limited slip like an eaton or something.
    Ira
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    no bro. I remember in 90 when dad bought her new from a dealership ;) and he never put anything in it.
    that's why I am :confused: if it were open diff only 2 of 4 wheels would spin.. :dunno:
  5. sandawgk5
    Oct 28, 2003
    6,881
    That is def interesting.
    Ira
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    i know what ya mean. so there is only one limited slip type deal gm had from the factory?
  7. sandawgk5
    Oct 28, 2003
    6,881
    I do not know if the gov-loc is a limited slip. I think it is a locker. There are several limited slips that were available but I could be wrong as I do not know if they were offered in trucks or Blazers.
    Ira
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    ahhhh!!!! :D i thought a gov-loc was a lim slip :haha: so it probably is a lim slip since a gov-bom is a locker?
  9. sandawgk5
    Oct 28, 2003
    6,881
    The easiest thing to do instead of quessing it to pull the cover and see what it looks like maybe post some pics.
    Ira
  10. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    hehehe true but that would require $$ and stuff :D it does need to be done anyway... prolly never been opened. so oil def needs a change.
  11. sandawgk5
    Oct 28, 2003
    6,881
    just gear oil and a tube of permatex. No need to buy a gasket, just use the tube of oil resistant permatex I believe the super blue works really well.
    Ira
  12. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    a gov loc is a half assed attempt to create a quiet locker, it is a cross between a posi/LSDand a locker, if a differance in axle speed is detected , it locks, but through clutch packs, as to eliminate(or reduce) traditional locker chatter
  13. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    have some silicone :D prolly black... or red lol most likely high temp... i dunno. know i have some that i used on two other rears when i changed the oil not too long ago.... may even have some 80/90w somewhere.. knew i bought a bunch but since my garage isnt built it could be anywhere lol
  14. sandawgk5
    Oct 28, 2003
    6,881
    I know what a gov-loc is the problem is his acts like a LSD but does not have an RPO code for it and he watched his pops buy it and knows nothing has been put in it.
    Ira
  15. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I am gonna bet it is a limited slip now after thinking about it. it would make sense to have one in a crew dually w/ 454 and 4.10's made for working... :waytogo: time will tell though :D
  16. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    what would the code be for an lsd?
  17. sandawgk5
    Oct 28, 2003
    6,881
    did not see in the first post that this was a 14 bolt. It could be an eaton LSD. I have seen eatons gov-locs and detriots. You would know if you had a Detroit.
    Ira
  18. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    The military got detroits in theirs, is the rear a dana70 or 14bff? If it's a dana70 then maybe a powr-loc? I know I can spin both tires w/ my dana60 w/ powr-loc.
  19. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    i think it is supposed to be a D70. I was told only the cab and chassis came with the 14ff for the duallys... :dunno: I will have to investigate.
  20. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    gm put power loc in from the factory in an 89 crew dually?
    also this wasn't a cab and chassis it has a bed on it that was bought that way.
