Is there any frame differences from a 1974 to a 1976 frame?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dhdescender, Jun 1, 2004.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    My 1976 blazer tub is currently sitting on a '78 frame, and one of the body mounts doesn't line up, becase the floor changed in '78. I'm after the crossmember that is just behind the doors and supports the floor.
    I've found a 74 that a guy is parting out, since the floors are the same, and same generation blazer, can I assume that this crossmember should be in there?
    Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes the 74 and 76 frames are the same i do believe /forums/images/graemlins/thumb.gif
  3. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    they are as far as i can see on mine.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    no major changes, but i do remember one specific change.
    the very front cross member where the brake distribution block bolts to is SLIGHTLY different. this should not affect your body swap at all.
    there was another couple differenceas but i cant not remember them off the top of my head at the moment. like i said, they are tiny things.
    grant
