is there any visual diff. between 4l60e and 4l80?
Discussion in 'The Garage' started by COCHEV, Dec 17, 2002.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    are the pans different? anyone have a link to pics or pan diagrams?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    A 4L60E is nothing more than a later version 700R4. The rear of the case uses only 4 bolts to retain it to the adapter whereas the 4L80 is nothing more than a TH400 with overdrive which uses 6 bolts to retain it to the adapter.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well...seeing as how the 4l60e is a 700r4 electronic version....the pan should be a rectangle.
    And, the 4l80e pan, being a 400, should be a really screwed-up, un-describable shape.
    Found some pics:
    TH400 (not same pan as 4l80e apparently)...... [​IMG]
    700r4 (4l60e)..... [​IMG]
  4. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    go to netgearhead.com, they have pics and gear ratios and other useful info on trannies
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    My 4L80 is mostly rectangle with the corners knocked off. They dont look like a TH400 pan.
  6. heavy4x4
    Aug 28, 2002
    3,270
    OOPS....MADE A MISTAKE /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif
    Summitracing listed it only as a pan for the TH400 - sorry, I guess I looked at it and thought...hmmmm, if it's a 400 pan, than it must be a 4l80e pan too. SORRY.
  7. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    Maybe it is just late I will take a pic of it tomorrow for you.
  8. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    later 4l60e(98+ I think) use an unboltable belhousing and the round six bolt pattern(same as 4l80e)
  9. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    thanks all. got her i.d.ed. was a 700r/4l60 /forums/images/graemlins/frown.gif
