Is there something you can put in gas to make an engine blow up?
Discussion in 'The Garage' started by ihatefords, Mar 6, 2006.
  1. ihatefords
    ihatefords Registered Member
    Nov 10, 2004
    28
    Wyoming
    I have recentlyt had two of my perfect running vehicles blow their engines! The first was my camaro and it had just got new tires and the oil changed. The oil was changed without my consent an PENZOIL was put into the engin with a WIX filter. These two brands are ones that i would never consider putting on my engine. Then the second incident was with my 86' K10. The motor has less than 8,000 miles since me and my dad rebuilt it. It started out in his stock car that he raced at a local track(shut down now). But the deal is that both of these vehicles were running fine until I left them somewhere. In the time that i left them unattended could some jackass add something to my gas,oil, or anywhere to make the engine blow up within 12 hours??
  2. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    Ive heard mothballs can do that. Turns gas into a type of jetfuel.
  3. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    depends on what you mean by "blow up"... what kinda failure?
    Mythbusters just did that episode and ran sugar, etc thru motors... don't think they found anything that would make em "blow up"
    plenty of things can be added to oil to fubar a motor...
    btw, Wix is a damn good filter...
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Agreed, WIX is a good filter.
    No idea on what happened to your motor though
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Wix x3, one of the best filter brands out there.
  6. ihatefords
    Nov 10, 2004
    28
    Wyoming
    Well my mototr was built with hyperutectic pistons and it is bored 80 over. I have heard people tell horror stories of hyperutectic pistons in the winter but as for the camaro the motor was completely stock. Both of them sou nd like they have broken the crank or busted a rod, but i have yet to rip them a part to find out.
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    .080 over?!
    Holy cow! No wonder that engine blew up! Most guys don't feel that good going .060 over!
    I'd tend to say that chances are your problems are probally coincidence, but if you are concerned about it, get a hood latch that must be opened from inside, and a locking gas cap, lol
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    x4 on the wix filters. Thats the only filter I run in mine and probably the best on the market. .080 over may be your problem on one of the engines. That leaves the cylinder walls really thin and can cause some problems. Sounds like the motors just went bad to me.
    -Harrison
  9. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    If its a big block .80 over isnt a big deal. Hows the oil look in the engines?
  10. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    If you put drain the oil and put bleach in it then you will definately blow up the engine for sure. Oh, and drain the coolant, and run an octane that is much less what is rated for your engine, then try to do a brake stand at full throttle for as long as the engine runs.
    That is just one way to blow your engine in an hour.
    But a better way is to put a supercharger on it and then you can call it blown:haha:
  11. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    valve grinding compound in the crankcase is prolly the sneakiest.. just squirt some out of the tube into the oil fill... breaks down in the oil and wipes the bearings out...
  12. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if you
  13. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if you add sugar to the gas, it will go, with the thin cylinder walls for shure.
  14. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    not in the gas...
    I think the quickest way to blow a motor is to add something nasty to the crankcase,not the gas.."Mythbusters" only "plausible" thing added to a gas tank was bleach,that could possibly harm the engine(it made a rusted mess of the gas tank overnight!)...but sugar,paint thiner,draino,and moth balls didn't seem to harm their SBC "test"motor much..
    I know if you put super high octane fuel in a motor it can burn valves and melt pistons..one guy I know ran 110 octane aviation fuel in his 400 Pontiac,and it burnt the exhaust valves in a few days of highway driving..
    I know of a disgruntled employee at one dealership nearby, that was ticked off about not getting a raise as did his fellow workers..he retaliated by adding a cup full of the metal filings from the brake rotor lathe in the shops service truck...it ran about 20 minutes,and by then,it had NO rod bearings,rings,or pistons in it..seized tighter than a bulls butt in fly season!..they could not even turn it over with a breaker bar to get the torque converter bolts off!..had to pull the tranny with it!..a 2004 Ford,brand new truck with 10,000 miles on it too...:eek1: ...
    BTW,a WIX filter is the best there is,or at least ONE of the best..had you said FRAM,I'd agree it might have been the filters that helped cause the meltdown..I have read bad things about Penzoil,but also know guys who won't run anything BUT Penzoil,and have never had any engine failures..boring your motor .080 over was not the best thing to do by any means..I'd lean more toward someone BEATING ON your motors while you were thinking they were safely stored,and doubt it was anything to do with the gas..
  15. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    from personal experience id have to disagree. i dated a girl that didnt like some dude and she dumped sugar in the brand new truck he got. couple days later the motor blew. he got another and she did it again and it blew again. needless to say i didnt talk to her much after that since she was so interested in this guy...
  16. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Twice! wow, that is some crazy b!tch! I hope warrenty covered it, twice. LOL:haha: :haha: :haha:
  17. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    The higher the octane rating, the cooler and slower burn you get. It probably had more to do with the additives (or complete lack thereof) in AV gas.
  18. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    wix = grear stuff
    and ..80 is big wow.
    i heard penzoil is wax based oil. yucky.
