is there speacial oil for limited slip rear ends?
Discussion in 'The Garage' started by cclemmer, Aug 2, 2004.
  1. cclemmer
    cclemmer Registered Member
    Sep 27, 2003
    7
    Texas
    is there a speacial oil for limited slip rear ends?
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    yes and no
    they make an additive that you put in your diff to preserve the limited slip. napa has it.
  3. cclemmer
    Sep 27, 2003
    7
    Texas
    do u know what it is called.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Go to the GM dealer. It is called Limited Slip additive, and about the best there is....
  5. cclemmer
    Sep 27, 2003
    7
    Texas
    what are some reasons for my rear end leaking oil?
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Where is it comimg from????
  7. cclemmer
    Sep 27, 2003
    7
    Texas
    the very bottom of my rear end.
  8. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif
    Replace the rear cover seal. Clean the surfaces very good. Make sure the cover is flat. Use some silicone, and a gasket....
  9. cclemmer
    Sep 27, 2003
    7
    Texas
    thanks
  10. cclemmer
    Sep 27, 2003
    7
    Texas
    i can not find any gaskets!
  11. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Really /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    10b gaskets should be all over the place....A bead of silicone that has had time to 'set' will work too....
  12. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    <font color="red"> how in the heck can you not find a 10b gasket? do u go to napa or autozone? or sum local garage? i mean, almost anyone should have a gasket for those, cus they're so common, but, silicone always works well, just make sure its made for it, dun go to home depot and grap a tube. lol. </font>
  13. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Yeah just run a nice bead of form-a-gasket and it shouldnt leak a bit, thats what I did to my daily driver and have had no probs.
  14. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Dont waste time and money on a gasket. Just use silicone, put it on the cover , put the cover on, add friction modifier and oil and its done.
