Is there such a thing
Discussion in 'The Garage' started by jamber2541, Dec 8, 2006.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    Is there such a thing as a vacuum leak inside the cab affecting the way the engine is running. My friend swears that he can hear a vacuum leak inside his cab and says his engine has ran like crap ever since it started ??
  2. dyeager535
    26,979
    I can't recall the routing, but there is a vacuum line on the brake switch, on cruise control equipped trucks.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yes, it's possible. All the heater controls as well as the diverter doors on an AC-equipped truck are vacuum-operated.
  4. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    my trucks have heat only, which is controled by cables, but trucks with air conditioning have vacuum hoses and cables running out of the back of the control unit.
    on ac trucks the hot-cold setting is cable operated
    when you use the off-max-norm-bi lev-vent-heater-def it sends a vacuum signal through little colored plastic vacuum lines.
    they all tee off from a regular black vacuum line from the engine, but i dont know exactly were it is. you can plug that one and see if it changes anything. i had a 78 monte carlo that they dry rotted and desintegrated on.
  5. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    also if it has a power brake booster it could be leaking at the firewall inside the truck.To test this all you have to do is pinch the 3/8 hose to the booster. mike
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If its loud enough to hear easily and make that much differance in how the vehicle runs, it probably is the booster.
