Is this 14bff a gov lock?
Discussion in 'The Garage' started by socal chevy, Dec 12, 2004.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    links dont work,
    but if it has 3 "pins" in the carrier, then its a gov-lock
    if it has 4, then its open
    the "pins" are about 3/4" in diameter, and just a little behind the ring gear
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    looks like a gov-lock to me
  5. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    So whats the differences in a gov lock and another 14b???
  6. readymix
    May 30, 2004
    6,706
    26
    The carrier is different. See above post.
    The gov-lock is not really designed for hard off road use. It will break. I can post pics of a broken GL if you would like to see.
    The 14FF gov-lock is stronger than the one in a 10 bolt but i have no idea how muck stronger.
  7. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    sure post it. I need a FOR SURE answer if this is a gov lock!
  8. readymix
    May 30, 2004
    6,706
    26
    Here is what the broken pieces will look like. This is from a 10 bolt. If you want to know for sure if it is a Gov-Lock then count the cross pins on the carrier.
    3= Gov-Lock
    4= Detroit (or) Open carrier. most likely open
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    hi, I recently asked this question also. Your carrier is a gov-lock carrier, I am sorry to say. Here is a link to the thread where I asked.
    http://coloradok5.com/forums/showthread.php?t=122279
    EDIT: oops, in the link I am asking about afactory 14 bolt detroit locker...but stallion85 posted pics of his gov-lock, and I have 2 links to pics of a carrier I believe has a detroit in it, which is just an open carrier with the spiders removed and the detroit installed. yours is definitely the gov-lock with no little holes to see the spiders thru. :(
  10. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    i dont know what a carrier is
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    ok, a quick answer would be the metal chunk inside an axle centersection that the ring (big) gear is bolted to. the gov-lock would go inside of this. the carrier is different for an open diff vs a gov lock diff, the gov-lock being less desireable because its a big turd and also you cannot swap a detroit locker into it, like you can with an open carrier.
  12. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    so the only reason why a gov lock is bad is because you can install a locker on it????
  13. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    It is bad because you cannot put a locker in it. You have to have an open carrier to install a Detroit. You will have to find a 14ff with an open carrier and use that. Or just get a spool :grin:
  14. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    I Don't mean to hi-jack your post, but is this true with a 14SF as well? Or can you take the gov-lock out and just put in a Detroit on a SF?
  15. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    you dont mean too?...you just did.
  16. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Or just weld the gov-lok and make a redneck spool :D Did that to mine, works great. My gov-lok had broken enough to not add traction but still work as an open diff, so I think the 14bff are somewhat stronger than other incarnations of the gov-lok.
  17. Tuff84blaze
    May 12, 2000
    119
    Sorry! Just thought they already answered your question, and I didn't want to start another post on almost the same question.
    I'm pretty sure the SF is different and you can put the detroit in place of the gov-lock, at least I hope so because I just ordered one for my Brother for x-mas.
  18. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    im messing with u... this thread is over. :)
  19. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    the whole center section that the ring gear is bolted to.
  20. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    You are correct :grin:
