Is this a 12 bolt ??? Pic
Discussion in 'The Garage' started by pornorob, Sep 18, 2005.
  1. pornorob
    pornorob 1/2 ton status
    Jul 12, 2001
    215
    ;jkl;
    :confused: So is this a 12 bolt ??.....if it is what is the part number for the ujoint that connects the diff and the drive shaft thanx guys :confused:
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i count 12 bolts so yes it is
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Chip away some of that rust so we can see it better to make sure,,, :D
    J/K looks like it to me also :waytogo:
    BTW, that is a REALLY cool loopy brake line there,,,kinda gives the brake fluid a ride there eh? :p:
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i counted 12
  5. pornorob
    Jul 12, 2001
    215
    ;jkl;
    thanx guys ... that could be why the stock rear u joint that I bought for it won't fit :D
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It will increase velocity, making the brakes operate better.
  7. divorced
    Jul 20, 2004
    5,115
    You probably need a conversion joint.
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    HMMM, :thinking: wonder how it would work with SEVERAL loops, :p:
    :D
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That lift block is scaring me .
  10. diesel4me
    Jul 24, 2003
    17,579
    945
    Massachussetts
    Brake fluid cooler!
    The "loop" is actully a brake fluid cooler!..I do that all the time rather than cut and re-flare a new line..ya,I'm a lazy F***! when it comes to double flaring brake lines!
    Anyone else notice all the "pre made" brake lines are either 4" too short,or a foot too long every time you go to use one??..must have taken them 20 years to figure out just the wrong length for 90% of all vehicles,huh?... :rolleyes: --I just buy the longer ones and "loop" em now.. :crazy: ..
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Yeah, the added length would have nothing to do with velocity of the fluid.
  12. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I agree. My brake line does this also. My tranny lines run back and forth across my rad aswell. Helps with cooling.
