Is this a 14 blt ff? ****(PICS)*****
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Sep 4, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    Well I just picked up the 14 blt that I bought. When I loaded it in it just looked different than the others I have seen. I went ahead and took it home because I thought it was just my mind playing tricks on me (who said that). Here are a few pics of the thing; can someone tell me if I got the right one? I thought these things had a very large lip on the bottom.
    14 Bolt pics
    Charles
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats sure looks like one, and yes that is the large lip at the bottom. It may not look like much now , I thought the same when I brought mine home.. but with it installed the lip will seem more pronounced.
  3. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Looks to be a FF to me. 4.56 gears is a nice find. How much did you give for it?
  4. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    i think it is! i am not real sure what a dana 60 looks like but judging by your pics i would say so.
  5. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yeah that's a 14b FF.
  6. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thanks for all the help guys. The cost of the axle was $150. They had at least a few there but this one had 4.56 on it and the spring perches were the same as mine (no cutting)
    Charles
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats the 14FF alright. That axle also came out of a 2wd truck, which will still work for your truck. You can tell its from a 2wd by the shock mounts. See how low they hang down? A 14FF from a 4wd truck has shorter shock mounts which sit up closer to the tube. Nothing to worry about as this axle is still a great piece to have and work with. /forums/images/icons/wink.gif
  8. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Just to add to what Wes said, I also have a 14 ff out of a 2WD 3/4 ton, and although those shock mounts do hang down a couple of inches lower than the 1/2 ton, the shocks that came with my 4" rough country lift were long enough. In fact, I ran them for a couple months like that.
    rob
  9. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    One questoin for ya. What did you do about the E-brake cable. Can I use the cables on mine and just put them on the 14 blt or do I need to get new ones.
    Charles
  10. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    how do you tell the ff from the sf when looking at them?
  11. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Full floaters have that big circular piece that sticks out of the brake drums with the bolts around it. You can see it in Ox's 1st pic.
