Is this a dana 44? PIC
Discussion in 'The Garage' started by inscape, Jul 12, 2004.
  1. inscape
    inscape Registered Member
    Oct 30, 2003
    82
    Washington
    Looked under my 89 and saw this http://home.comcast.net/~inscape/blazer/front_axle.JPG It also has a 12 bolt in the back. I'm assuming whoever had it wanted different gears and just swapped axles? What's the easiest way to check gear ratio?
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    yep looks like a 44
    as for checking the gear ratio, pull the cover then write down the numbers on the ring gear, and post em here, and someone will tell ya.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep.....that is defiantely a D44. As for the gear ratio, you might get lucky and have the little metal tags still attached to each diff.....but if not, then do what smprider suggested above. /forums/images/graemlins/waytogo.gif
  4. bowtiebstrd
    bowtiebstrd Registered Member
    Feb 13, 2004
    56
    Jacksonville, NC
    without pulling the cover, you should be able to jack up the front and count the number of driveshaft rotations compared to tire rotations to get an estimate of the ratio. marking the driveshaft and tires helps as does having a buddy there.
