Is this a Detroit Locker? (w/pictures)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Nov 8, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Ive never even laid eyes on a Detroit locker before, and I just bought this 14b ff from a guy in Wisconsin---He said it has a Detroit locker in it. Is this a Detroit?
    Click here for pictures
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You really can't tell that well from the pics because on a 14 bolt the detroit goes inside of teh stock carrier. However, I don't see the teeth on teh side gears through the case, so it appears that there may be a detroit in there. If you look through those windows and all you see is a solid looking chunk of metal, then it's a detroit. If you can see any gears, it's open. </font color>
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    It does look that way...mostly because you can see any spider gear teeth in the little window.
    Rene
  4. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Any other opinions?
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Its a detroit IMO
  6. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Yep, open carrier with a detroit in it.
    Mike
  7. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    looks like a detroit... definitely not a gov-lock or open w/spiders.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    looks like a Detroit to me, almost looks like you can see the side springs
    never seen a lockrite or ? so couldnt compare
    definitely has a drop in locker tho /forums/images/graemlins/thumb.gif
  9. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    On top of that, the olive drab paint on the housing kind of gives it away as a CUCV rear. As long as no one has messed with it, all of those came with 4.56 gears and detroit lockers.
    Mike
  10. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I would agree with M_J on that one. I have the same setup in my 14 and thats exactly how it appeared. One way to really check is to bolt some tires on the axle and make sure it's elevated. On one side, rotate the tire either forward or backard about a half a revolution. Immediately stop the tire from turning - this should lock in the Detroit. Now rotate in the opposite direction and both tires should turn in the same direction. You may need someone to hold the other side still when you first try this - that assures the locker will engage. When the locker disengages, you will hear the gears "ratchet".
