is this a good cam choice for the 454? any tbi people?
Discussion in 'The Garage' started by supersize75k5, Mar 4, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I need to order a cam and comp cams recommended..
    CCA-11-232-3 Camshaft, XM262H, Xtreme Marine, Hyd Flat Tappet, 262/268-218/224-.505/.515-112
    this is for my 30 over 454 block, with the plan to add tbi in the very near future.
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/ears.gif
    -shawn
    what cams are the tbi big block guys running?
  2. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Check out these cams for the TBI 454 to minimaze problems with the computer:
    Crane 134122
    Edlebrock 2162
    Comp Cam 11-206-3
    Lunati 06202
  3. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    BTW the specs on the Comp cam I listed (Part # 11-206-3) are
    Duration 203/212 @ 0.050 lift
    0.460/0.485 valve lift
    Too high of duration will cause problems with the computer. /forums/images/graemlins/waytogo.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you tell Comp cams everything including carbed, or type of FI, computer/non-computer, then I think the one they recomend is the way I'd go.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    None of the Xtreme line cams will work well with fuel injection. Their lobe seperation angles are too tight.
  6. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    ok so what cam do you reccommend?
    they recommended that one /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just went and checked out the specs on that cam on the website.
    I think it will work. Lobe seperation angle is 112*, which is generally accepted as EFI-friendly.
    RPM range 1000-5000 /forums/images/graemlins/thumb.gif Sounds perfect to me.
    Sorry to mislead you, I should have checked the specs on it first.
    I had an Xtreme 4x4 in a previous motor that would not have been TBI friendly. Generally they're ground on 110-111* LSA but that line of BBC marine cams is an exception.
  8. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I run the next step down from the cam you have spec'd on my 454. The truck hasn't left the driveway yet but the motor is very responsive and the TBI fuel mixture seems to be just fine. I do have a custom chip and a few mods though, so I'm not sure how a factory set up would do.
    Comp cams will be your best bet on getting the right cam for your truck and driving.
    Mike
  9. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    tim...your alright,
    I dont care what thay say about ya, /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/histerical.gif
    p.s. I stole that from Marve..but it always cracks me up
