Is this a good deal for a Dana 60??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz88K5, Jul 26, 2001.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    Well i found a Dana 60 rear for 300 bucks....4.10 gears with a trac loc locker in it...it needs to be rebuilt ...dose that sound like somthing i should jump on?
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Sounds like somthing to jump on and ride all the way home. [​IMG]
    Se Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, good deal there. You cant find too many D60 for that much WITHOUT the track lock!!! [​IMG]
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  4. Chaz88K5
    2,979
    Stockton/Lodi CA
    welp i am broke as a joke but i guess i am goin to have to do some scrounging for cash....maybe ill pick it up this weekend!
  5. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If it's a 35 spline, it may be worth that. If its a 30, I wouldn't bother. The shafts aren't much better than what you have, and the 35 spline upgrade is not easy. The only advantage I can see to a 60 over a 14 is the better ground clearance. It sounds like you could get into a 14 bolt and Detroit for maybe only a few bucks more than you will have into this 60 by the time you rebuild the limited slip.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Around here, a rear Dana 60 that needs to be rebuilt is definitely NOT worth $300. Prices may be differernt in your area, but 14-bolts and rear 60's ready to run with the just the addition of gear lube and maybe brake pads go for $100-$150.
    A couple of other notes:
    - The rear Dana 60 will have to be modified (spring and shock mounts moved) to bolt into a Blazer.
    - A Trac-loc may be better than an open diff, but not by much. On the street and flat surfaces (wet grass, muddy field) they can help some, but for serious fourwheeling it's pretty much useless.
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    He lives south of Sacramento.... $300 for this area is a very good deal.... everything here is very expensive so you'd be hard pressed to find one for less....
    I'd get it Chaz... price around recycle row here in Sac and they'll be wanting $500 for the same thing and even more...
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    All the 14 bolts that I've been involved with were purchased for $100 or less. 4.10 is the most common ratio. I've also turned down plenty of 60s in the same price range.
    Pete
  9. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I must be living in the wrong place! I cant even touch a 14bolt for under $400, and a front D60? ya rite try at least a grand.....
    <a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
    " Wider IS Better!!!"
  10. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Try Pick &amp; Pull, 33rd &amp; Peoria in Aurora. The paper is also a good place, but it isn't quite the same since the whole JOA thing started. Front 60s are hard to come by, around a grand seems the norm. I paid $750 from Denver Used Pickup, I just happened to call the morning after they got a K30 in. This was after looking everyday farily seriously for a year. As far as front 3/4 ton 44s or 10 bolts, $200 seems like a good price around here. IF you're looking at 3/4 fronts, don't be afraid of 10 bolts, they seem to be more available and are really no better/worse than 44s. If you can, though, I'd hold out for a 60 if you plan to do any serious wheeling, it'll save $ in the long run.
    Pete
