Is this a good deal on a th400?
Discussion in 'The Garage' started by denver75k5, Oct 31, 2003.
  1. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    $200.00 for a "Short shaft" TH400 with kevlar clutches, and a reverse pattern manual valve body.
    Should I jump on this?
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    sounds great to me as long as it is low mileage or rebuilt fresh.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    sounds good to me also, i know i have picked up one "running" for $150 and one "running" 400/203 for $130. Nothing special about them and have yet to see if they are in fact "running.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sounds like a good deal. Depending on the valve body, that alone could be worth the change...
  5. denver75k5
    May 15, 2001
    1,017
    Thanks for the input guys, I went and picked it up yesterday. /forums/images/graemlins/rotfl.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    short shaft as in 2wd, or short shaft meaning 4x4 ?
  7. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Does it have compression braking?? If not I wouldn't get it.
  8. denver75k5
    May 15, 2001
    1,017
    Well its a 2wd trannie but the guy said it was a short shaft,,,, Hmmm do I need to change shafts to convert it to 4wd????
    Toby,, too late I already got it...
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I don't think you'll have to change shaft's, it seem's to me that a short shaft is the same as a 4x4 trans. /forums/images/graemlins/grin.gif
  10. denver75k5
    May 15, 2001
    1,017
    I did a lenghty search here and there seems to be a lot of debate on the strength of a 2wd case,, hmmmmm , how much weaker are they really?
    Also I plan on going with an atlas T-case so im sure they make an adaptor for it, but I just want to do it once and do it rite /forums/images/graemlins/thumb.gif
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just add a second crossmember to support the weight, and you should'nt have a problem. /forums/images/graemlins/grin.gif
