is this a gov-lock?
Discussion in 'The Garage' started by broncoman6524, Dec 19, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yes and Yes
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Actually, the first link the ad says its a G80 and an Auburn posi, which the picture isnt either. The posi has clutches, not cones like the Auburn, it looks more like a Ford Track Lock.
    The second picture is a gov lock.
  4. readymix
    May 30, 2004
    6,706
    26
    I can see the clutches. Unless I am not understanding you correctly.
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    An auburn posi (like in the diagram)has cones that go into the case and bite, when they wear out the case is all worn away, thus making them less diserable bcause they are basically disposeable, you cant rebuild them.
    The one inthe picture has clutches and a big S sping, when the clutches wear out you can take it apart and replace them.
    He says calls it an Auburn and a Gov Lock, its neither.
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    that 11.5" govlock is pretty burly
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    so the first one is NOT a gov lock and the second one is?
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Yes. The first one is a limited slip of some kind. It looks like the factory limited slip my bro had in his camaro. Bottom is a Gov-loc.
    Ira
  9. readymix
    May 30, 2004
    6,706
    26
    Oops. I did not see the pics when I looked at the first one last night. I only saw the graphic at the bottom.
  10. sandawgk5
    Oct 28, 2003
    6,881
    It really looks like a factory Positrac. Does not look like Eaton or Auburn:dunno:. It def aint a gov-loc.
    Ira
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, thats why im tayin it looks more like a Ford Tack Loc because of the big S spring. GM posis have plates against the side gears and 4 small springs. Thats what you get with ebay.
  12. sandawgk5
    Oct 28, 2003
    6,881
    GM also used the S spring on Positrac units. I put one in a 10 bolt with my brother. Readymix even rode in it and we thought we blew it up:D.
    Ira
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Oh yeah yeah thats right on car 10 bolt posi's. I was thinking about 12 bolt, where they have the plates and 4 springs.
  14. sandawgk5
    Oct 28, 2003
    6,881
    I know very little aboot 12 bolts only that they have 2 more bolts than a 10 bolt:D.
    Ira
  15. dyeager535
    26,980
    I suspect those (S-spring posi's) are Eaton units as well as the 4 spring one, too lazy to go dig up the car manual and see what GM called it. They are stock, but only seen them in cars.
  16. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I had one of the S- Spring units in my 83 GMC Jimmy 10bolt. Looked just like that. Far as I know, it was a factory item. It blew up after making some horrific noises for awhile.
    John
  17. dyeager535
    26,980
    Alright, anything other than full-size trucks. :)
    But you are right, see these in the 7.5" and 8.5" 10 bolts, but never seen one in a full size truck.
    Of course, I know the GM full-size truck manual shows a limited slip Eaton unit for the trucks, but never seen or heard of one in an '80's truck. ( which is what the manual is)
