Is this a limited slip diff. in my 14 bolt?
Discussion in 'The Garage' started by Zooman, Mar 21, 2007.
  1. Zooman
    Zooman Registered Member
    Jul 10, 2000
    35
    Ontario Canada
    Hey guys I am changing the diff fluids in my diffs and I want to see what if I have a limited slip in my 14 bolt before I add the gear oil. Just in case I need to add that special additive in the oil.
    Here is a pic. Can you tell me for sure what it is. My truck is a 78 Chevy 4x4 3/4 ton. My rear axle is a ff 14 bolt.
    Thanks guys
    Matt
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    if you were a member i would link you to the 14ff id helpers gide with pics. but you are not. so i will tell ya. yes its a gov-lock rear end. or comon name of gov-bom as the stock ones in the smaller axles blow up real easy. the 14ff is the strongest of them all. i love mine in my daily driver truck. use to be in my mud truck and worked good also with 38 swampers and built 400 sbc. if you know how to use them thay can last good for what thay are.
    ah heck here ya go if it works for ya. http://coloradok5.com/forums/showthread.php?t=151608
  3. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Perfect
    Thanks for the help.
    I tried a search yesterday before I put the cover back on but I had only searched for pics of a limited slip.
    I appreciate the link but it's not working.
    I just did another search for gov-loc and just read a ton of posts. I never thought to count the pins on the dif but it looks like I have three. So thanks for letting me know what I have.
    Matt
  4. K-5 Bomber
    K-5 Bomber 1/2 ton status
    Aug 20, 2006
    108
    Northeast California
    Save me some time, Zooman. What's the Gov-Loc look like & how do you ID one? Thanks for throwin' a lazy brother a bone ;)
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Check out the pic below...
    Look for the pins that come through the differential (red arrow).
    Count the number of ring gear bolts between two of the pins (blue arrow).
    If there are 3 ring gear bolts between two pins, it is an open differential.
    If there are 4 ring gear bolts between two pins, it is a GovLock.
    In the picture below there are 4 bolt between two adjacent pins, indicating a GovLock.
  6. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Perfect info!
    Thanks for posting that response Divorced.
    I don't have any doubts that I have a gov-loc. I haven't had a chance to wheel this truck at all so I am not sure it the gov-loc works. I hope so.
    Thanks guys.:saweet:
    Matt
  7. K-5 Bomber
    Aug 20, 2006
    108
    Awesome! Thanks.
  8. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    that red arrow points to the end of a spider pinion............a govlock has 3.......an open has 4.
    Thats why you can't put a detroit in a govlock carrier. the carriers are not the same.
