is this a posi?
Discussion in 'The Garage' started by makovai, Nov 26, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I identified the ring and pinion as a richmond 4.56
    but i'm still trying to figure out if its a posi.
    Is this picture enough to tell. How can i tell?
    This is the 12 bolt out of my 72 blazer.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Looks to be an open carrier. Take a pic of the ring gear side of the carrier. Also how did you tell what gear manufacturer? Is it marked Richmond on the gear somewhere? What are the teeth count of both gears.
  3. makovai
    Jun 6, 2006
    854
    oregon city
    Like this?
    As far as the gears, yes they were well marked on the ring gear so it was easy to id it.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    yeah thats an open
  5. makovai
    Jun 6, 2006
    854
    oregon city
    Ok, so whats open mean exactly. does that mean this isn't the original rear end. my glove box id says posi.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Get a much better angle pic so that i can see the ring gear bolts and the carrier near the cap.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well if it has Richmond gears and 4.56 at that then someone has already been into that rear end since GM never put a 4.56 gear into a 12 bolt in a blazer.
  8. makovai
    Jun 6, 2006
    854
    oregon city
    like this?
  9. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Open...
    Was prolly a Gov-Bomb from the factory, although usually they called it a locking rear diff on the options sheet. The orginal carrier prolly got fragged in either case.
    Rene
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yep, and definately an open carrier. Looks like a thick ring gear also. That means your carrier is for 3.07-3.42 ratio.
  11. makovai
    Jun 6, 2006
    854
    oregon city
    meaning it could be the original rear end but someone change the entire carrier and gears? And there is no ifs, ands, or buts, it has 4.56 gears in it.
    And the final anlysis is its not a posi, correct?
    And there is no if's, and's or but's it has 4.56 gears in it. that i know for sure.
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That is correct. If you find the BOM number on the axle tube then someone can tell you what the application of that axle originally was. The BOM number is usually found on the passenger side axle tube on the top side just inboard of the spring perch.
    In case you don't know, BOM stands for (Bill Of Materials)
  13. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    It could be a swapped in 12 bolt, or a carrier and gear replacement...definitely not stock ratio and definitely not a posi, Gov-bomb or otherwise.
    Rene
  14. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Couldn't have been a Govbomb, they didn't come out till the late 70s....Probly Eaton or Auburn style posi...
  15. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    you know an easy way to test if its a posi or not is to put one tire on pavement and another on the grass and power brake it. both tires spin then its a posi. If you rotate the ring gear around to see the other side you can tell if its a posi or not. If it has a little latch with a spring on it that can swing into the spider gears then its a posi.
  16. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    and if its a worn out posi or a posgovlok?
  17. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    That one is a peg leg.
  18. makovai
    Jun 6, 2006
    854
    oregon city
    i'm not sure what you all are telling me here.
    I dont really care if its an original or not cause i've already converted to a 14bolt. I just want to sell this one and its kinda hard when i cant tell people what i have. I can say for sure it has spring perch distance for the 72 and older, it has 4.56 gears, but what kinda of carrier is it for sure.
    Can i shoot more picture? find more numbers? what do i do from here?
  19. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The carrier is a factory stock carrier.
  20. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    it is an open carrier, that means NO posi
