is this axle a 10b or a d44? picture is there
Discussion in 'The Garage' started by 88jimmyoungowner, Jan 6, 2003.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Kinda hard to tell, but by looking at the diff cover and the odd tie-rod setup like I have seen on early blazers, I would have to say Dana 44.
    Check out the diff ID guide on here.
    Rob
  3. Grim-Reaper
    7,385
    Atlanta
    Is this under your 81?
    Sure looks like a 44 with a flat top passenger side knuckle.
    That's the same tie rod my the D44 that was under my 75 had. As far as I know they never ran that style tierod on a 10 bolt either.
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    its a 44, one way to tell is it has a Check oil plug on it, plus a ten bolts pumpkin is more round, Im sure you can put those check oil plugs on ten bolts too, but they come factory on D44s.
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I agree....it is a Dana 44. The easiest way to tell is to look for the two round depressions on each side of the cover. Those are for the D44's case expander when you R&R the diff case. If you look you can see the depressions just under the tie rod on either side of the cover. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Most definately a 44. I could tell right off because the driver's side of the diff cover is flat. </font color>
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    D44, another thing to look for are the straight sides on the diff cover.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats a "first design" D44 axle. This means this axle is a '76 or older D44.
    The giveaways are:
    1. Flat top knuckles, both sides
    2. Small tubes, measuring 2 3/4" diameter
    3. Tie rod has the stabilizer mounting hole in the middle of the rod.
    If this axle were the "second design", it would have the following:
    1. Flat top knuckle on the driver side only, for the steering arm.
    2. 3" diameter tubes.
    3. Tie rod with stabilizer mounting hole would be on the driver side, by the tie rod end.
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    To be like the 10th person to agree, I have to say that's a 44. I've had both a 10 bolt front and a D44 front and that is a D44.
    -- Mike
  10. 88jimmyoungowner
    Nov 20, 2001
    425
    georgia-rome
    thanks for the help guys, i tried the axle identification chart thingy, but i did not understand it too well.
