Is this bad?
Discussion in 'The Garage' started by MTChevy, Sep 13, 2006.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    is it bad if you change your tranny fluid, etc about 350 miles ago and you check it and it is burnt to hell? 92 Chevy Silverado 1/2 ton... towing a trailer down to Laramie, Wy. Im gonna change filter and fluid again today. Man i hope this trans dont give up on me on the way down. I still got a couple hundred miles to go!
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    848
    Pinckney, MI
    if your worried, drive for 20 minutes take a break for 10
    drive for 20 etc. It will take longer, but it will get ya there.
  3. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    ill be sure to take it easy
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Lucas transmission fix, almost as good as a banana in montana
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    How long had it been since the last tranny service, Cole?
  6. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    since i last changed the fluid and filter? 350 miles or so:eek1: you shoulda seen all the sludgy stuff that came off the magnet dealie near the drain plug... its a 700r4
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'll recommend the Lucas stuff to get you to Laramie. After that, tranny fluid cooked at 350 miles is never a good sign.
    You run a 241 case correct? If so, my tranny would be a bolt in and I've got a spare TH400 on the way so I need the room in the garage.:p:
  8. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    yep 241 case
  9. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    the transmission has been great, but that 350 miles with the trailer suuuure gave it a work out... and im not even quite halfway there yet:eek1: :eek1:
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    What color was it? What'd it smell like? How does the tranny act when you're driving it? Does it have a cooler? Do you have a temp guage?
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Oh yeah, what gear are you running it in at what speed with how heavy of a trailer?
  12. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    brown, smelt like burnt tranny fluid, tranny acts fine when driving, just runs higher rpm;s to keep the trailer goin, so no use of overdrive, no cooler and no temp gauge
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    As long as there's nothing in the filter and it acts fine I say change the fluid and run it (not like you have a choice at this point anyways), and change it again when you get there. Might wanna consider a bigass cooler when you get around to it too. I can take a pic of the ports to use the next time I get home.
