Is this doubler combination possitle?
Discussion in 'OffRoad Design' started by BurbinOR, Jan 17, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Well, actually I figure anything is possible, but is this something I just need to procure parts to do --
    T350 trans (or for that matter 700R4) - NP203 for a T350 - NP205 for a T350.
    Reason I ask is I have a T350 (newly rebuilt, very strong), already have the NP203 from the factory, and have a line on a NP205 locally for a T350 with adapter.
    Thanks in advance................
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  2. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    It's possible. A good friend used a 27 spline shaft to mate his NP203/NP205 combo. But I dunno if Stephan sells that shaft or not.
    --Rob
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like the Gen. I you are asking about.
    If we can get enough demands for the Gen. I to come back, Stephen should be able to put it back into production, you would think?
    I want a Gen. I Doubler for my 465.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. mudduck
    mudduck 1/2 ton status
    Jun 30, 2001
    245
    wentzville mo
    yes , i just finished doing it myself I had a turbo 350 tranny that was just rebuilt very strong used a 203 from 350 turbo and a 205 for a 350 turbo i used the 203 shaft and had Moser cut it to length and respline and heat treat it. would have went with ORD stuff but no more Gen I doublers being made wish we could get enough people interested to bring it back i went this route because i already had all the parts to do it this way.
    MD79
  5. BurbinOR
    5,829
    Oregon
    Very cool info............did you have to take the 203 completely apart or did the shaft come out without disassembly. Please let me know...........and thanks.
  6. mudduck
    Jun 30, 2001
    245
    wentzville mo
    i havent tested this setup yet in the process of converting to a front D60 in my 79 shortbed. this setup is a little longer than the Gen II doubler dosent seem to be a big issue on my shortbed not for sure in a blazer i built my own adapter and used the factory adaptor between 205 and 203 box still have to make my shifters and linkages, i can send you some pics and some of my drawings if you want, i built my own driveshafts and all pieces i needed excecpt the main shaft had Moser do it, go to www.bc4x4.com and look in the tech section under wrenching it should give you a good idea on how it is done he actualy used a 700r4 tranny, my set up is similar it is not really hard to do but i did have access to all machines needed to do this but the shaft, it only cost about $100 give or take a few to have shaft and coupler done at Moser, hope this helps.
    MD79
  7. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    think this will make it clickable
    <a target="_blank" href=http://www.bc4x4.com/tech/2000/gordtcases/gordtcases.cfm>www.bc4x4.com/tech/2000/gordtcases/gordtcases.cfm</a>
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't think the 27 spline shaft is up to big tires. We've had a couple of broken 27 spline shaft back here, one was a TH350 input gear, the other was one of ours. That's one reason we make you use a 32 spline shaft. Plus the length, cost of the factory 205 adapter, cost of replacement 205 adapter if it breaks and lack of clocking ability, or simple clocking ability. Plus everyone wants the beefier part so there is really very little demand for the Th350 gen1 kit now.
    We might be better off just building what people want, but at this point I really think the GEN2 is a better way to spend your money. For some guys the Gen1 style will work fine, even long term, but for hard use it's not as strong and I hate to see you have to spend the money twice. With a GEN2, you can do anything you want with it, power, tires and driving style are all up to you.
    Think about this, a new adapter to replace the TH350/205 housing is $350 or more. Drivesleeves will run $100 - $125. Input gear is $150 or more.
    I'd say sell the whole TH350 setup to someone that wants it with a TH700 or TH350 and start with a 10 spline 205. It may be cheaper overall anyway.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  9. BurbinOR
    5,829
    Oregon
    Being that I run 35" tires and *more than likely* won't go bigger, add in the fact that I have the T350, NP203, and NP205 already, I can't see selling it all and starting over. No way, especially if it has already been done. I just somehow have to figure the disconnect between your response basically quoting $350 for the 350/205 housing (what are you saying here?), another drivesleeve $100plus the input gear for $150. Think I'm in over my head on misunderstanding what you are saying versus the Ryeguy and mudduck making it sound like a simple adapter/shaft cut/respline/heat treat on the 203 output..............
    Can anyone clear this up for me?
    ONE TON</font color=blue> <font color=green>TPI'd</font color=green><font color=red> BEAST<font color=red>
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The problems we were running into are guys that don't have the TH350 version 205 that needed the shorter length. We were selling a lot of new input gears, drivesleeves and adapter housings. At this point you end up ahead in strength and price starting with a manual version NP205 and going with the GEN2 compared to buying conversion parts to make the 205 a TH350 version then buying a Doubler for it.
    GEN2:
    Doubler kit $740
    Conversion of NP205 to 32 spline input $250
    GEN1:
    Convert NP205 to TH350 version, roughly $500
    Doubler kit $740
    The TH350 conversion parts can vary a lot but I had to price new or mostly new parts. Of course this gets a lot cheaper if you already have the parts or buy used.
    We've quit the GEN1 type because of this cost, and the length. I'm not ruling out building some more in the future but we can't jump back on it right now. I also like the fact that the Gen2 is good for any tire/power combo as I mentioned before.
    Is there anyone else looking for a TH350 GEN1 Doubler? Maybe we can look into it more seriously.
    SW-ORD
  11. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I would like to see the Gen1 come back because I have a Turbo 305 version 205 and I also have a 400/203 combo. This would prevent me from having to disassemble my 205 to have the bearing hole machined, and buy the 32 spline female conversion parts. It would save me some bucks!
    '85 K5 : 330 HP-350/350/205/FF14/D60/36 inch TSL's
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 205 is SO easy to disassemble.
    no special tools required(maybe a dummyshaft and the proper snapring pliers i guess)
    formerly 77chev
    still a jerk though
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i would love to see it come back. but at the same time i wouldnt. i need to use the gen 2 because i am planning on running 39.5 boggers or thornbirds.
    grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  14. BurbinOR
    5,829
    Oregon
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    wont go bigger than 35s Blazzin? Come on now, i know you want those 39.5" Swampers! or bare minimum some wide 37s! ;)
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  16. mudduck
    Jun 30, 2001
    245
    wentzville mo
    yes a drive sleeve was used it also had to be worked by Moser, and i am sure they could reproduce the adaptor me and my brother did mine and i am working on making another one, i am only running 35s and dont plan on going bigger on my rig havent tested it yet but truck should be ready soon.
    MD79
  17. BurbinOR
    5,829
    Oregon
  18. BurbinOR
    5,829
    Oregon
