Is this drag link angle ok?
Discussion in 'The Garage' started by pismorat, Sep 1, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I just replaced my old 2.5" Rough Country springs with 4" BDS's. It is way better than before, but I was wondering if this angle was ok. I offroad pretty hard when I do, so will it be chill? I have a guy with a 6" lift and steering correction that would sell me his, would it work here?
    [​IMG][/url][/IMG]
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That angle is a bit much. You want the draglink to be level.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    steering arm will fix that
  4. pismorat
    Oct 29, 2002
    540
    California
    What's better, a drop steering arm or a raised drag link? I think my buddy only has the raised drag link, but I won't be sure until I see his truck this weekend. With a 6" lift could he have both??
  5. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    I would use a dropped pitman arm, the one on the steering box. (which is different than a raised steering arm)
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It looks too much to me as well but, as much as I hate to disagree with Muddytazz, I put a 4" arm on mine and it made the arm level to the ground. This gave me really bad bump steer. You need a bit of drop in the arm to compensate for the upwards/rearwards movement of the axle. As the axle rises it travels backwards too because of the shackles. The drag link needs to follow this arc too. If it is level to start with it fights againts the arc of the axle and causes bump steer.
    I should think a 2" pitman would do the job.
    Just my 2 pennies worth taken from nasty experiences!!
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I had a raised steering arm..... but Panther has it on the d44 I sold him.... I may have my drop pitman arm but have to look. I am going away on vacation today at noon so wont be able to check until monday night.. drop me a pm if you are interested... really dont want much as it is taking up space and im trying to clean up....
    lemme know
    Jeff
    since I went d60 I didnt need the steering arm... and went xover so dont need the pitman arm....
    xover is soooooo nice :bow:
