Is this for real?? Or another Ebay gimick!!
Discussion in 'The Garage' started by CaveBlazin, Dec 11, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
  2. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Never seen one of those. Would be a kewl way to do it, I don't see why it wouldn't work.
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    I cant really figure how it works? *IM not a smart MAN*
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I've seen them before. They sort of get sandwiched between flywheel/flexplate and crank. They are thick and can give you problems with clearances for torque convereter or clutch.
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    I've used one of those before (still have it ) I had no problems with mine (used mine with a 454 in front of a SM 465 ) there OKAY to use just keep the RPM's down I ran mine until I could afford a Flywheel then pulled it out if you can afford it I would buy a flywheel instead of this and that's a bad price anyways I got mine for 12 bucks at my machine shop
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i have used those things with no trouble at all for years on race cars,,,turning in excess of 7500 rpms.....the thickness factor is negligable considering the clutch is adjustable and the converter had at least 1/4 inch of play to work with....it is simple and cheaper than buying a weighted flywheel...IMHO
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    still recommend taking wheel/plate in for balance check at a shop no matter what though
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    this will work very well a co-worker that was building a 400 small block to cascar specs. Had used a similler one to make a 350 flywheel fit a 400 as they are next to inposable to find a(manual)flywheel for a 400 and he said it worked great so... /forums/images/graemlins/thumb.gif
  9. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    This is one of the biggest rips ever! Guys tell other guys that a 400 SB balanced, manual tranny flywheel is impossible to find, when one from a 454, is basicly the same thing.
    This balance plate is cheaper than a flywheel, but do you still need a balanced harmonic balancer?
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes you do. My 388 uses a ext. balanced harmonic dampner and weight that has been welded to the flywheel mounting flange on the crankshaft. This is a rather handy method of balancing a externally balanced engine because it allows you to swap flywheels/flexplates with out a need to rebalance. /forums/images/graemlins/thumb.gif
    Summit sells a balancing plate similiar to the one in the Ebay ad for use with their 383 kits. /forums/images/graemlins/thumb.gif
