Is this odd?
Discussion in 'The Garage' started by sled_dog, Mar 23, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Since i put my new engine in whenever I remove my gas cap to refill I can hear pressure releasing. I never had that before wtih my 305 or previous 350. Same fuel pump and carb, gas tank, everything in the fuel system is stock as it always has been.
  2. Can Can
    15,555
    152
    Cochrane, Alberta, Canada
    Did you alter or remove any of the vacuum lines that are connected to your evaporation cannister?
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    my entire vaccum system was screwy after the last motor install but my dad and I took some time and redid it to the diagram on the radiator support. At least I think its the same as the way it should be.
  4. Can Can
    15,555
    152
    It sounds to me like at least one of your gas tank return lines got plugged off during the engine swap. I can't think of anyhting else that would lead to pressure in the tank.....
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    The cap itself is probably bad and what you hear is air rushing in to fill the vacuum created in the tank. Just a guess though.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hmm tank cap was new 6 months ago when I got it inspected. Have to look at the returns.
  7. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    pressurized tank... Cool now you can run upside down...hehehe...
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you are stock EFI it should be that way.
