Is this opportunity knocking?
Discussion in 'The Garage' started by colbystephens, Oct 12, 2005.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i need a new rear end for my truck - currently it doesn't have one. The motor will be going to the machine shop this week and will be there for a couple of months and i figure i should work on getting the driveline together so that when i get a working motor back in the truck i can drive it. i think it would bug the crap out of me to have a brand new motor in a truck i couldn't drive.
    anyway, here's my point. i ran into a guy today who offered me a newly rebuilt (only 1000 miles on it) 10bolt rearend with 3.08 gears and an auburn locker for $200. i was going to just go to the salvage yard, pop the $130 (cheapest price in NW Oregon kinda sux.) and just throw a used 10bolt under it so i can drive it. i'm not an experienced offroader yet - so a 14bolt and gear ratio change isn't quite necessary yet - someday, just not yet. I'm trying to avoid having to put money into the front end yet - that's why i don't want lower gears yet. anyway, what do you think between my two options. should i pop for the extra $70?
    Thanks!
    Colby Stephens
    www.web.pdx.edu/~colbys
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    the answer depends on tire size the weight of your right foot really
    how big are you tires?
    what do you offroad in?
    how much do you love the skinny pedal?
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'm just going to run 35's, i'm doing the standard 4" lift, and it's a 6.2L diesel motor - so speed's not really an issue. i generally drive moderate in terms of how hard i lay on the fuel pedal - i try to be good to the motor but have a good time here and there. :)
    also, since it is a diesel i'm going to switch it over to biodiesel after i get it running - you can't be 70 cents per gallon at 20 mpg! as a result, it will be a daily driver as well as my offroader. it's hard to beat that cost - i suppose you could beat that with a hybrid car, but who wants that? anyway, how hard is it going to wear my back tires with a fully locked rear diff on the streets?
    colbystephens
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Given those 2 choices only, I would spend the extra money for the $200 unit.
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    any other thoughts out there?
  6. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    It depends on who rebuilt it. If it's only got a 1000 miles it could have issues and he's just saying it's basically rebuilt. I'd almost go with a used one that has 50K miles on it. It's gonna last you as long as you need it to. The rebuilt one may only last a few thousand miles if it wasn't done right. Anyways, I smell what you're stepping in. I himmmed and haaahed until my 10 bolt exploded, then bought a 3/4 ton front and rear and I'm still not all that confident in them. Dude claimed he was a mechanic, the gears were 4:56 with a detroit in the rear, and I still kindof wonder if they are going to grenade on me. Sometimes I just wish I would have found a used 10 bolt and ran that. Would have saved me a lot of trouble.
  7. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I would just get a 14 bolt. That way you dont spend money twice on the rear axle. In my opinion it's not worth it to do so. I would look for a 14 bolt semi floater or full floater. Then build it like you want it, gears, locker, ect. I understand about not wanting to touch the front but If you run 35's on 3.08s I would bet my bottom dollar that its gonna be a dog and will kill your gas mileage. You might want to check around a bit. 35's are gonna drastically change your effective gear ratio. Compairing 35's to say a 31 inch tires its gonna give you an effective gear ratio of 2.73.
    Anyways with all this rambling, I would suggest doing a 14 bolt semi or full floater. Then do gears and lockers as you please. (I would stay away from a limited slip of any kind but thats another story)
    Dustin
  8. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Read hunterguy86's post. read it over and over. He's dead on.
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks for the info guys - something to think about for sure. i know who built the axle - it was built by a company which is well respected for their work. the guy i'd be buying it from just wants it off his yard - hence the price. anyway, you've given me a lot to think about. keep posting info if you think of anything else - the offer's out there for me and i don't realy have any competition or timeframe. i just want to decide in about the next 3-4 weeks.
    colbystephens.
