Is this part important?
Discussion in 'The Garage' started by shupach, Jan 12, 2004.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i had to pull the tranny to replace the TC and flexplate, in the process i broke wat looks like either a vent tube thats been extended or some sort of vacuum line that hookes up to the carb, it looked like it was hooked up to the passenger side of the transmission. anyone know what this is?
    phill
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Are you running a TH350? Sounds like it might be your vacuum modulator line.......
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya th350, i was just look over my chiltons and couldnt find anything.
    phill
  4. Can Can
    15,552
    136
    Well, if it is indeed your vac. mod. line, yup, it's important. Better make sure you get a replacement.
  5. shupach
    Dec 28, 2000
    648
    Dallas, TX
    wat does it do? doesnt look too hard to replace, just alot of grease to dig through.
    phill
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Tells your tranny when to shift up or down by facum instead of just the kickdown cable. Your truck will run terrible (vacum leak) and the tranny will be poppin gears like a rental quad.
