Is this part really needed to be used????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Nov 6, 2003.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    The choke pull off valve. Really needed? If so Why? I have an electrice choke also on my carb, (Q-jet), no EGR, no smog control devices, etc. The choke pulloff has a vacuum line coming off it and connecting to the back of the carb. Is it a redundant system? It also has a allen screw adjustment. But what for? Anyone running without the choke pull off? Thanks!
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it pulls choke open slightly(when engine is cold of course) when you depres gas pedal alot, so that you wont choke the engine of air it needs and flood it, but you really wouldnt need it if you keep off the pedal when engine is warming up, alot of vehicles didnt have them, but some did, probably depended on year make model and emissions equipment installed
  3. dyeager535
    26,979
    They are designed to pull the throttle plate open just a hair when the choke is set.
    I can't recall EVER seeing a q-jet that wasn't set up this way, although some of the early early ones may have been.
