is this piece important
Discussion in 'The Garage' started by stoney126, Sep 6, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all, While pulling the studs out on the dana 60 steering knuckle this piece that I think is plastic or thin rubber came off. Do I need to replace it? Does it act like antivibration or just a pad?
    I can get pics if needed
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm pretty sure you're describing the thin rubber gasket that sits between the steering arm and the knuckle. It's basically just a seal that prevents water from creeping into the kingpin area. If the gasket is still good, re-use it. If not, a little bead of RTV can be used in it's place.
  3. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    cool thanks man
  4. Can Can
    15,552
    136
    Anytime, brother!!! :thumb:
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Its a sure sign of the apocalypse - the Can Man dispensing advice in the Garage.:D
  6. Can Can
    15,552
    136
    I knew that was coming.......:rotfl:
    I may not be a gearhead, but I still have a little bit of experience working on these here trucks, y'know.
  7. cbbr
    Jul 17, 2004
    14,681
    More than me by far when it comes to a 60.
  8. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    can can got his 60 info from some other place. :rolleyes: :rolleyes: :haha:
