Is this possible??
Discussion in 'The Garage' started by 1985K20, May 19, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Seems to be hard to get an answer for this but i'll try it again!
    Can i put 265's on a 10 inches wide rim???
  2. dyeager535
    26,975
    If my math is right, that's a tire just under 10.5" wide. Seems awfully narrow for a 10" wheel, definitely not much rim protection, if any.
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    That would make a good run flat!!!!LOL :D
  4. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    I have read you can go 2 inches wider or narrower of rim size :)
  5. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I don't have a direct answer, but I would contact the tire manufacturer and ask them.
    I'm currently running 38.5x16x16.5 TSLs on a 12" wide wheel. The maximum recommended rim width as stamped on the side of the tire is 9.75" (and thats for a 16" wide tire!!!!). If I had to do it over again I'd run what the manufacturer suggested.
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I've run 35 12.5's on 6.75" wide stock steelies...also had some 39.5" x15 x15's on a set of 15 x 8's. No trouble with either.
    Rene
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yes, you can put them on there... but you will get some sidewall bulge and it will be fairly easy to knock a bead off the rim. I have seen 31x10.50's on 12" rims... looks HOMO, but it can be done.
