Is this really that simple?
Discussion in 'The Lounge' started by 84gmcjimmy, Mar 6, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Its warm out so I started thinking...
    The front yard is a mess with weeds we never pulled last year. If I can rent one of those hand rototillars and chew the ground up. Then pull the weeds, then plow push the dirt semi flat and plant seeds. then use the roller and whatnot for the seeds.
    Is it that easy? Or am I overlooking something? I will get some pics tomorrow so you guys can judge...
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Sounds like a pain in the ass.
    Just pull the weeds and pour beer on the lawn.
    It's gonna look a mess in between and may not come out perfect
  3. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Unless you covet hard work, be afraid. :eek:
    Anticipating Pics.
    :thumb:
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I can't just pull the weeds, they are in there good.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Where's that thread I made about this last year?
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Stave's a lazy post whore who doesn't want to look it up! :D
    NOTE: - I'M KIDDING!
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Out to get pics, pics will be up in the next .5 hour.
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    pictures:
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    The only part I can properly grow grass in right now is the side of the yard that the house sits, up to the pile of 2x10's, from the 2x10's to the road is just dirt/clay/rock still.
    In the area I mentioned, is it possible to use a rototillar to chew up the ground, then pull the weeds out so I can plant grass seeds?
  11. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Burn them!!!:weld:
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    burn them?
    there isn't enough close together to get the whole thing lit up. if I used gas it'd work, but I dont want to polute my soil:p:
  13. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Rototilling that would be so much work.
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    why? If its gas (or electric, whatever they are) all I have to do it push it?
  15. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Your kidding right? I will say that it would be a great work out for You:deal:
    :rotfl: :rotfl: :rotfl:
  16. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Steve,
    A rototiller doesn't work well in compacted soil like your yard will likely be. Your best bet is probably going to be mowing the grass/weeds you have now, apply a fertilizer/weed killer and some new grass seeds. Make sure you pick seeds that are good for the low light area's under trees.
  17. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    Soak your yard down with water, then buy a huge set of boggers and chew the weeds outta your yard! rake them into a pile and burn them - smooth out the surface and apply grass seed and straw and your set for spring!
    1.) You get to play in your 4x4 throwing mud everywhere!
    2.) You get rid of the weeds all without having to push anything!
    3.) Drinking beer while doing this will increase the effects of #1
    :laugh: That's how I would do it!
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Give me a break!
    Kenny The ground isn't really hard. How soft does it have to be for a rototillar to work? I'll mow when it dries a bit, everywhere I step I sink. Don't need to buy a new lawnmower.
    Flatline, I don't have any money for boggers, want to send me some for free:grin:
  19. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    rototillers are not so much pushing forward, as holding it back, it will tend to want to run across the top of the compacted soil, and you want it to get down into the soil a good 6" (maybe more), so you will mostly be holding the thing in place, slowly moving forward
    for the area you have pictured, you will want it for at least a day, maybe more, and you will have A LOT of fun ;) and be VERY sore when you're finished
  20. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Don't let them fool you, they're just trying to pull a fast one on you again.:D Shouldn't take you more than a couple hours to do that.
