Is this spring required in my hubs???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, Jul 22, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I have taken apart the hubs on both sides, one side had a spring in it, it's about 2" wide & 5" long (as seen on page 8-14 of a haynes). The thing is one side didn't even have this & as far as i know that side worked just fine. Do i need this with locking hubs or is this something from when it was fulltime 4wheel drive?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You do not need the spring, it was needed when it was a fulltime 4WD without locking hubs.
  3. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    It depends on what brand of hubs you are using. Warn doesn't need it, Spicers do. That spring pushes the cog out that engages the bearing hub on the Spicer set up.
  4. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    well then i guess i lucked out, I'm using the warn hubs /forums/images/graemlins/thumb.gif
