Is this the Root of my Evil?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5_beater, Nov 4, 2002.
  1. k5_beater
    k5_beater Registered Member
    Jun 11, 2002
    35
    New Jersey (Armpit)
    I have gone throught two axle seals in less than 4 months and about 500 miles. I think that is could be my bias ply tires' (TSLs) flat spots. Is it logical? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    So is it just leaking or is it eating the seal out?
  3. k5_beater
    Jun 11, 2002
    35
    New Jersey (Armpit)
    it is spraying gear oil all over my brakes. i think i caught it before it got really bad
  4. Grim-Reaper
    7,385
    Atlanta
    I would check for a bad seal surface on the axle shaft or a warped axle shaft.
  5. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I'd have to agree with Grim, sounds like it could be a bent axle shaft.
    You also might want to make sure your breather cap is not clogged. Warm gears build pressure and it has to come out somewhere.
    Good luck.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Or a bent axle tube.
    It's hapened to me before and guess what?
    I had a friend that bent the axle tubes on a 14bFF.
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    are you putting any gear lube on the seals as you put them in? you may be burning the seals before they a chance to get gear lube to work into them
