Is this too much cam for a TBI truck?
Discussion in 'The Garage' started by y5mgisi, Dec 11, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    heres cam specs
    Basic Operating RPM Range: Idle-5,500 RPM
    Intake Duration at 050 inch Lift: 204
    Exhaust Duration at 050 inch Lift: 214
    Duration at 050 inch Lift: 204 int./214 exh.
    Advertised Intake Duration: 262
    Advertised Exhaust Duration: 272
    Advertised Duration: 262 int./272 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
    Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
    Lobe Separation (degrees): 112
    Intake Valve Lash: 0.000 in.
    Exhaust Valve Lash: 0.000 in.
    Quantity: Sold individually.
    Camshaft, Hydraulic Flat Tappet, Advertised Duration 262/272, Lift .420/.442, Chevy, what do you think?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    What size motor?? The bigger the motor the "less" the cam will be. Meaning on a small motor the cam will sound bigger, and the bigger the motor the cam will have less lope to it. I ran a 268 cam in my TBI 406. Dunno the specs off hand, but cams was Comp Cams Xrme Energy 268. Didn't have any problems.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    nevermind i found out that its a fine cam for tbi. Its a 350 though just so you know.
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    that would be a fine cam, Im running something very similar to that in my 383, but do plan on doing a bit of tuning though.
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Yep, that'll work great in a factory EFI application! Good choice!
  6. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    actualy SierraClassic, it was you in another thread that i found telling someone there cam was fine that had the same specs as mine. So thanks you answered my question before i even asked it.
  7. Russell
    Jun 23, 2000
    7,923
    333
    Just be aware that that cam is a bit more geared towards a higher end engine, and you'd probally want to go with the bigger 454 throttle body, and an aftermarket intake to allow the engine to breath a bit better. Any stock 350 TBI I've had fell flat on its face at about 4800 rpm, which is a fair bit below the powerband of the cam you've selected.
    Its a big mistake that guys make, putting way too much cam in for an EFI system. I'm personally looking at an XE256H Comp Cams Computer camshaft, which makes power from 1000 - 5200ish rpm. Even considered an XE249H, but I think that its worth getting the slightly bigger cam, simply becuase I'm running a slightly more exotic TPI setup, which can be made to flow a bit easier than a TBI setup.
    If you want to run stock EFI systems, your goal needs to be building an engine that is geared for low end grunt, and is built to operate within the restrictive abilities of the stock EFI system itself. If you want a high performance engine that is built to make big power, and rev really high, you want to consider an aftermarket EFI system, or a Gen III engine swap.
    Yes, the stock systems can be made to make big power, but it costs big bucks, and takes a large amount of time to get it tuned properly.
  8. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    That is damn near identicle specs to my LT1 L89 cam in my rig and I have no problems with it at all.
  9. Russell
    Jun 23, 2000
    7,923
    333
    That would be a roller cam though, big difference between roller and hydraulic lifter cams. Roller runs far smoother and works very well with EFI, even with far more aggressive profiles.
  10. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Also, What does this thing do? could it be a part of my problem? Its the ONLY thing i havent replaced.
  11. Russell
    Jun 23, 2000
    7,923
    333
    That one backs off your timing when knocking is detected by the knock sensor
  12. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    oops! meant to post this in the other thread! My bad. But thats good enough. thanks for all your help so far Russell!
