Is this what I think it is?
Discussion in 'The Garage' started by ankarback, Sep 5, 2005.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    I opened up the rear axle in my new suburban to change the oil and to check the axleratio and I found that there's some kind of locker in there :D
    I've never seen one in an axle but am I right to think that this is a Detroit locker?
    I also tried to figure out the axleratio but found 108 and 20 and that make no sense at all. Can anyone figure that out for me?
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    if calculation serves right that gear ratio is 5.40's. seems like an odd # to me and really low..
  3. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    That's what I got too but I don't beleive it. It doesn't feel that low, I´m guessing 4.11 or 4.56. I´ve never heard of 5.40, hope the frontaxle is the same ratio as the rear :doah: . I'll have to check that tomorrow.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    The gears inside the carrier show to be an open dif. Sorry, don't see no DL in there.
    Count the teeth again. Mark where you start and get back with us. The numbers you posted should be for something else rather than the gear ratio.
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    wrong numbers!
    The gear ratio is stamped on the outer edge of the ring gear--it will say something like " 40-10-73" that would mean 4.10's and manufactured in 1973,as an example..I'm not sure about what locker that is (if it is at all)..someone else will have to identify it for you.. :crazy:
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    look on the edge of the ring gear there will be a series of numbers. POst those up and we can tell ya.
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    how many holes on the circumfrence of the carrier 3 or 4?
    4= detroit iirc
    3=open iirc
  8. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Then I found the wrong numbers. It sure looks strange for an open diff. It looks like it has two pinionshafts?? I thought it might be a locker because of that :blush: Just wishfull thinking I guess...
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    The last 4 sets of numbers on the ring gear edge will tell you the ratio. should be XX XX XX XX. The last 2 are the date code, and the two before the date code are the number of pinion teeth and the number of ring gear teeth.
    The numbers you found are in the carrier casting itself and could mean anything...
    As for locker or no...it looks as open as open gets to me. The DL would have spring windings visible through the carrier windows.
    Rene
  10. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Then it´s open :( It was definetly no springs visible in there. Looks like I'll have to check the gear ratio again.
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    4= detroit or open
    3= gov-lok
  12. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    makes sense now that i think about it. thanx :bow:
  13. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    You should be happy with a open diff, easy to weld or slip in a DL! I've sold a fiew open diffs in my day but have a hard time giving away a Gov-bomb!
    Every time I pull a cover of a 14FF for the first time my heart speeds up just a little thinking of the slight chance of there being a Detroit No-Spin in there. :eek1:
    I know it's very unlikely but GM did strange things over the years.
    Jeff
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Like put them in CUCV's from the factory :D
  15. jason m
    jason m 1/2 ton status
    Feb 12, 2005
    173
    holland mass USA
    its an open diff, 14bolts have a two piece sandwitch style carreir like the one you pictured, i belive ( and dont hold me to this ) but the gov-loc locker has three holes for the cross pin not four like your is pictured.
    they can be deceving ( the carriers ) cause when you open up the cover it does not look like a conventional carrier, i said the same thing a long time ago when i pulled a nine inch apart, they look like the same, jason.
  16. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Just think if the CUCV 14FF pile got mixed up with the civilan(?) pile! :D :D
    Was the Detroit No-Spin put in at GM or buy the military? Or some sub-contractor?
    Jeff
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I THINK it was put in by GM...someone please correct me if I'm wrong.
    But yes, if there's a Detroit in a 14bolt, you'll definitely see a spring when you look into the little window in the carrier. I'm sure somebody will have a picture of it, I forgot to snap a photo when I had mine opened up.
  18. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    The reason I thought it might be a detroit in the first place is that i know the PO replaced the axle a while ago. I thought that maybe it was from a M1008 or something. Looks like it's quite easy to put a locker in there so i might do that in the future.
  19. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    They don't all have the springs visible. I know this will probably start a huge heated debate, but the 14 bolt with a DL that I own has no springs that I can see from the outside of the carrier (never had it apart, but I looked and they arent anywhere to be seen). I also own an Eaton H052 w/ DL, which is the 14 bolt's predecessor, and its open carrier looks almost the exact same. There are no springs in that, either. I also have another Eaton with an open diff, and you can clearly see the spiders. Its easy to tell between the two.
    In both of these axles, all I can see is smooth metal in the holes where you see spider gears in the above pic. I don't know if they were both installed improperly or what, but they don't have the springs.
    :dunno:
  20. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I don't know either man, all the ones I've seen you can see springs. Either way I think everybody's in agreement that this guy definitely has an open carrier.
