Is This Worth Keeping?
Discussion in 'The Garage' started by k5 beast, Nov 10, 2005.
  1. k5 beast
    k5 beast Registered Member
    Mar 21, 2005
    22
    memphis, tn.
    I was given a lincoln quick weld welder. Its an arc welder with a 20%duty cycle, 70 amp output,17volt output. It is supposed to weld up to 1/8 inch. Does anyone have an opinion on this unit.
  2. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Hell yeah cant beat the price.
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    It's small, but better then duct tape (the lack of welder) that you may have otherwise. :p:
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Learn to weld with it, it will make you a good welder later.
  5. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    The hardest part with the 110 stick welders seems to be striking an arc. Once you get started they weld ok. I would never buy one new since they can't do anything a 110 wire or 220 arc can't do better but they are kind of fun to play around with. I paid $10 for mine at a swap meet. Still can't weld sheet metal with it though-blows right through it. I have had some success welding exhaust pipe and thinner plate with the 3/32 rod. Like someone else said-learn to weld well with it and a "real" welder will be much easier.
  6. k5 beast
    Mar 21, 2005
    22
    memphis, tn.
    Thanks for the advise. I especially like the one about duct tape. I actually used duct tape for its actual intended purpose the other day for the first time ever, while winterizing my house. When I used the welder for the first time the other day all I did was make holes. I was just practicing with some angle iron. I also got it stuck once. The damn wire either comes out too fast or too slow. Although I'm sure its the operator.
  7. k5 beast
    Mar 21, 2005
    22
    memphis, tn.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    So is it an arc welder or a wire feed then? :confused:
  9. JSH
    Oct 20, 2002
    75
    Iowa
    I assumed you were talking about a 110 arc(stick) welder but by the specs you listed you must be talking about a 110 mig or wire feed. If so disregard my post. :doah:
  10. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    If a wire feed, then you are holding the stick too far from the workpiece if you get stuck, and too close if you blow holes in the metal. You should have about 1/4"-1/2" of wire sticking out of the gun, hold it at an angle that affords you a good view of the wire and the work piece, flip down your mask, click the button and watch the puddle. As soon as it looks red in the mask, start moving slightly. You want to keep the puddle moving without blowing through the metal. Make gradually larger circles at first, until you can make a perfect circle about the size of a quarter without blowing out any holes. After that, start working in straight lines on a pice of scrap flat stock. When you can do decently straight lines with your mask down on a single piece, then work on joining 2 pices of flat stock, first with spot welds, then doing a full bead. Hope it helps a little... that little Lincoln will be your best friend in a few days. =)
