ISO: information on fairly narrow, driver's side pumpkin, front axle
Discussion in 'The Garage' started by dremu, Feb 7, 2004.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    ISO: information on fairly narrow, driver\'s side pumpkin, front axle
    A friend of a friend of ... is wanting to convert his early 60's Econoline truck to 4WD. Apparently he needs a front axle with a driver's side pumpkin. Also, as this is a fairly small truck, it needs to be ~ 61" WMS to WMS (drum-to-drum).
    Yes, I know it's a Frrd, but it's early iron and besides, anybody who does 4WD conversions on old trucks that were not meant to have it ... is crazy enough to be OK in my book /forums/images/graemlins/laugh.gif
    Apparently an early Wagoneer axle is the right width, but has the passenger side pumpkin, so must be cut and re-tubed, an expense and hassle that this guy wants to avoid.
    We've also heard that early 60's through early 70's Ford F-100 trucks came with a driver's side pumpkin, but no-one seems to know the width of these axles.
    So, to help the friend of a friend of ... out, I'm polling you folks, to see if y'all can identify an axle for us, which has a driver's side pumpkin and is the right width. Any takers?
    -- A
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Re: ISO: information on fairly narrow, driver\'s side pumpkin, front axle
    look for a 70's Early Bronco...Drivers side drop D44 with disc brakes by 75. WMS-WMS should be about right too.
    Rene
  3. dremu
    Feb 27, 2000
    15,963
    454
    Ya know, that was my first thought, but the friend whose friend whose ... drives an EB, and its front axle is ~57" WMS-WMS.
    Damn those EB's are damn small! I'm so used to Burbs making my Blazer look small that I forgot how goddam big a K5 is /forums/images/graemlins/laugh.gif
    -- A
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    It's within 4" of what he is looking for...so he could always run less Backspacing to get the width where he wants it.
    Rene
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Randy Harral @ driven auto in phx is the early bronco guru....freind of mine and has an all domestic 4x4 wrecking yard. Phone number is 620-269-9204...or of course... www.drivenautoparts.com.
    Also see alot of 4x4 vans running around here...actually saw a 70's chevy 4x4 conversion trun in front of me this week by the house...had that way 70's decals and all...it was actually pretty clean from what i saw of it.
    DW
    DW
  6. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I'm not sure what years of FS Cherokees had them,but,some of the later ones have a front axle like you want.I know where there was one near home.{Tenn.}I'll see if it's still there when I get home{around Feb.20}and post again.I think it's a D44.I know it's a six lugger cause I thought about using it under my truck,but,it wasn't wide enough. /forums/images/graemlins/peace.gif
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    you cant just flip the axle over?
  8. ZonkRat
    Jan 16, 2003
    1,003
    I've seen them flipped,but,to get the castor &camber right the ends have to be cut off & turned to get it to drive decently.
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    The tires also turn the wrong way when flipped.... /forums/images/graemlins/eek.gif
  10. ZonkRat
    Jan 16, 2003
    1,003
    That's right.When you flip it the ring gear is on the opposite side & makes the tires rotate the wrong way.This only works if you put a front diff in the rear to get rear steering. /forums/images/graemlins/waytogo.gif
  11. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Have him check the later model Fullsize Jeeps. I think they switched to DS drop in or around 1981.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How come nobody has mentioned the 73-79 Fords? F150 axle will get ya coil spring cups or F250 will get you leaves.
  13. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Because it'd be about 8-10" too wide...
    Rene
  14. dremu
    Feb 27, 2000
    15,963
    454
    Wassa fullsize Heep -- like a WJ or XJ or whatever they call a Cherokee?
  15. ZonkRat
    Jan 16, 2003
    1,003
    The old fullsizes were wagoneers or Cherokee Chiefs,I think it depends on if it's a 2 or 4 door.That's what I meant when i said FS Cherokee.They only made the driver side diff a couple of years.I know they were six lugs and I think they are D44s. /forums/images/graemlins/thumb.gif
