Issue with a modified block similar to a zero rate
Discussion in 'The Garage' started by Yukon Jack, Oct 14, 2003.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I recently got new 6" front springs so I pulled my old 4" springs off. About 2 years ago and probably only 500 miles ago I added a block similar to the zero rate center bolted block up front. I had mine made with a bit of a taper to them - can't remember the exact amount but it was what is typically used with about a 6" lift. When I pulled the center pin to remove the tapered block I found that the head of driver side center pin was bent slightly. Who knows if it would have ended up breaking. I'm glad I'm back to having no center pinned block up front and just wanted to give a heads up on my finding.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Center pins pretty much break no matter what. On my rear springs with no blocks both heads were sheared off of the locating pins.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm never thought about that...im ging to be running some of these blocks with 4" springs up front..will they need to be taperd any? i was thinking i would just attatch plain 1" blocks ot the leaf packs and that be that.
  4. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    The only reason you would need to taper them si if you needed to correct pinion angle.
