issue with complete driveline swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by desertrat67, Jan 1, 2005.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    ok, in june i bought an 84 GMC 3500 body and frame to put all the components from my chopped up 88 Chevy V30. When i was mounting up the tranny crossmember it did not line up in the same spot. It used different holes in the frame and those didn't even line up propperly. I ran without the front shaft in for a while and when i went to put it in the shaft was too long. Was there that much variance between frames between 84 and 88 to cause this? I looked at the motor mounts and there is only about 1/2 an inch of fore aft movement possible. Do i just get the shaft shortenned(don't want to since i think the old one was too short anyway) or is the something i can do to move the driveline back about 2-3 inches.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did both trucks use the same tranny and t-case? A difference there could account for a length difference. T-case adapter could have changed in that timeframe also.
    Either way, sounds like it's time for a trip to the driveshaft shop. ;)
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    i took the engine tranny t-case out of one and put it all into the other. oh well, i guess it is shortenning time or just wait unitil i can afford a doubler and get a longer front shaft and relocate the crossmembers to accomodate that.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    But the question is... Did the tranny a t-case of truck 1 match that of truck 2? If one had a Turbo 400 and the other had a 465 then there could be a difference in the total length. :)
