It dosen't fit! M*&^#r F!%k HELP
Discussion in 'The Garage' started by mollyman, Jan 6, 2007.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    So here is the story. I have a 81 k10 sub, it had a 12 blt in it. I bought a 14 blt ff rear end from a military surplus place. I had the bright idea to measure the spring perches before we broke our backs getting it in place and the 12 blt perches are 42.5 inches from center to center, the 14 blt I bought are 40.5 from center to center. Also the shock mounts are like 2 inches off. So whats the deal? Everybody told me that it would bolt right up! Can I just cut off the perches and reweld them in the correct location? Or am I screwed!!! Any ideas out there. Please help I got a 14 blt taking up valuable space in the barn when it should be under my truck!!!
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Only the 14bff3/4 ton will bolt right up. You got the 1 ton, Now you have to buy new perches and shock mounts.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You bought the 1 ton version not the 3/4 ton version. All you have to do is move the spring perches and relocate the shock mounts. If by everyone you mean your friend then I can believe "everyone" told you it would bolt right up. This swap has been covered on here aboot 1X10 exp 12 times. If you got the 4.56 detroit version that almost all military trucks had then moving perches and shock mounts is def worth it.
    Ira
  4. sandawgk5
    Oct 28, 2003
    6,881
    Damn Im slow me and my long winded posts:doah:.
    Ira
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    better check gear ratios too. military had 4.56 kind of rare to find that in a civilan model
  6. mollyman
    Aug 18, 2006
    280
    west virginia
    Yeah it has 4.56 and a detroit (and I only paid $200 it was unused in a crate). But can I reuse the perches and mounts or do I have to buy new ones?? Thanks!!!!!!!
  7. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    good score. Grind those welds and break those suckers off. Or you could spend more money as mentioned and buy some new mounts and perches.
    Mine was the same way, a pain in the arse but well worth it. I re-used the old stuff.
  8. sandawgk5
    Oct 28, 2003
    6,881
    I would think if you are careful when you remove the old perches you should be able to reweld them in the new spot.
    Ira
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You can. I started to take mine off with a angle grinder and a sawzall. That didnt work so I cut them off with a torch. I was still able to re-use them afterwards and they are fine now after 4 years.
    P.S. Mollyman- Did you happen to get it from a place called Clarks Truck Parts in Poca West Virginia? If so, I hope you dont have anything wrong with it. Those people are assholes and will NOT fix any problems with the axle even if they sold it to you defective. They told me in person when I bought mine from them that they would gladly fix anything that wasnt right after I installed it....and when I discovered a possible problem and called them about it...they basically laughed and said f u. NOBODY do business with clarks truck parts in poca, wv!!!!!
    -Harrison
  10. mollyman
    Aug 18, 2006
    280
    west virginia
    No, I didn't get it there. But thanks for the info. If I mess up the perches removing them where can I get some replacement ones? Anbody know? And how did you line them up and everything? I'm just worried about getting them in the right spot. They both need moved out exactly 1 inch.
  11. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    New Perches
    Check the vendor forum or go here---> http://Diy4X.com
    Kert makes some incredible stuff.:bow:
