It drives!! Well, it drove
Discussion in '1936-Present Suburban' started by desertrat67, Apr 23, 2007.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Well, drove the sub for the first time in a few months tonight. This was also the break in for the new gears. I finally have 5.13s in both axles, not one axle and my work table. I need new shocks, to adjust my headlights, check tire pressure, repair the exhaust(cut it to clock then decided to unclock) and shorten driveshaft by 1.5 in. Then I will be done...for now.
    I drove for three days and tehn I blew a fuse. It was the gage/idle fuse. This is my instrumentsand also is part of the glow plug circuit. I decided to check out my wiring around the engine bay since I had seen some shady stuff under there that I thought could live a little while. Well that was it, a little while. I found 10GA twisted and taped to 12GA wire, 16GA to 14GA and some other stuff. Now I am looking for anyone with a 90 diesel that can get me a pic of the wiring to/from the Glow Plug relay/controller so I can get this looking better and hooked up correctly. I haven't been ableto find a wiring diagram for this either, so if you have one I would greatly appreciate a copy.
    Here is my mess.
  2. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Pics! Pics! Pics!
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Guess I'll have to do this today. Not as pretty as yours, but I really didn't get it for its form.
  4. CumminsChick
    CumminsChick 1/2 ton status
    Jan 19, 2007
    127
    Lexington KY
    mine looks like hell too.
    does this diagram help any?
  5. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    hey thanks. I might be able to get it going with this.
    ryan
  6. CumminsChick
    Jan 19, 2007
    127
    Lexington KY
    if you need it in an email or clearer, i can try emailing it. that's in my Haynes manuel for diesels.... hope it helps =)
